how do you remove retaining nut from steering wheel?
Old Feb 7, 2005 | 12:45 PM
hatchinprogress's Avatar
Default how do you remove retaining nut from steering wheel?
hey everyone im trying to take off my stock steering wheel (to install my quick release wheel kit) i do have a haynes manual and all it says is to remove retaining nut (no pit) well i tried with a 19mm nut but the nut will not budge.......so can anyone give me any pointers???
Old Feb 7, 2005 | 12:46 PM
dr_latino999's Avatar
Default Re: how do you remove retaining nut from steering wheel? (hatchinprogress)
Make sure the wheel is at full lock, then using a nice size wrench (18" should do) give it a spin. You may have to hold onto the wheel and stop it from trying to spin as this way you are not putting as much stress on the locking mechanism.
Old Feb 7, 2005 | 12:53 PM
chivic's Avatar
It really helps to use a 19 mm deep socket. I used my 2 foot breaker bar and held it with one hand. I also used some penetrating oil ,which helped greatly.
Old Feb 7, 2005 | 12:56 PM
91civicEX's Avatar
Default Re: how do you remove retaining nut from steering wheel? (chivic)
the manual says not to use the steering lock. it seemed pretty certain when i read it. but as we say at work "hey its not my car" it is a 19mm and there is no trick in taking it off but turning it.
Old Feb 7, 2005 | 01:01 PM
Del Sol SiR's Avatar
use an impact or a breaker bar, remember, "lefty loosey, righty tighty".
Old Feb 7, 2005 | 01:02 PM
Default Re: how do you remove retaining nut from steering wheel? (91civicLX)
thanks for the info ill go give it a try(again)
Old Feb 7, 2005 | 01:44 PM
ok i got the retaining bolt off......now would anyone happen to know how to install a quick release hub kit?
hellcivic1996
Jan 1, 2007 03:32 AM
dustin_crxsi
Oct 30, 2006 05:29 PM
DooD
Sep 17, 2005 11:51 PM
metalgears
Jul 25, 2004 12:08 PM
SloVXHatch
Jul 18, 2002 07:56 AM
