B16a Throttle Body
Old Feb 7, 2005 | 11:13 AM
caranjo's Avatar
Default B16a Throttle Body
I need a quick yay or nay. Will the 89-92 b16a crx/civic throttle body fit in a JDM B16A2 Del Sol?
Old Feb 7, 2005 | 11:28 AM
dohcdelsol93's Avatar
Default Re: B16a Throttle Body (caranjo)
all b series throttle bodies mount the same but your map sensors will be different map sensors from 1st gen to 2nd, it will also be smaller in diameter.
Old Feb 7, 2005 | 11:43 AM
caranjo's Avatar
so does that mean i can use the TB from the 89-82 b16a civic in my JDM b16a2 1993 Sol? would i have to modify the map sensor?
Old Feb 7, 2005 | 12:36 PM
Default Re: (caranjo)
the older map sensor is mounted on the fire wall as opposed to the newer style that mounds on the t.b. I wouldnt use it any way, it has way too many vaccume lines and has a smaller, more restrictive bore. U can buy them for 50 bucks, any 94 up ls tb will work fine.
nitro911
Aug 23, 2011 09:40 AM
whtciv99
Jul 18, 2009 09:01 PM
b16delsol
May 17, 2004 09:06 PM
zerofighter777
May 27, 2002 01:43 PM
Red Civic T
Aug 27, 2001 03:50 PM
