Cam Gear Adjustment
Old Feb 7, 2005 | 10:45 AM
JDM00SI's Avatar
Default Cam Gear Adjustment
sup ive receently bought an 00'si w/ full brakes,suspension and bolt ons. I have JG cam gears on stock cam shafts. i was told that the cam gears are not doing ****, since im on stock camshafts. I was thinking maybe buying some Type R cams or skunk2 ...not sure yet. Although is this true? how do i know which angle my cam gears are adjusted? thanks
Old Feb 7, 2005 | 10:51 AM
JDM00SI's Avatar
Default Re: Cam Gear Adjustment (bigbeasta4)
http://www.cardomain.com/id/jdm00si
a picture of the cam gears and thier adjustment is on the above link on page 2.
thanks
Old Feb 7, 2005 | 08:57 PM
JDM00SI's Avatar
i have no clue what to do with my cam gears.
Old Feb 8, 2005 | 09:16 AM
PrettyLude's Avatar
since its there make the best of it, or you can do a timing belt job and change them
Old Feb 8, 2005 | 11:07 AM
JDM00SI's Avatar
Default Re: (PrettyLude)
i already changed my timing belt before i installed the cam gears. although i do not know how to tune/adjust them, i was told i must have aftermarket cams in order to do that. is this true? how would i adjust it if i do buy some aftermarket cams? thanks
Old Feb 8, 2005 | 05:27 PM
PrettyLude's Avatar
the only way to see gains or not is on a dyno
Old Feb 10, 2005 | 09:56 PM
JDM00SI's Avatar
so are my cam gears set to 0 degrees. is it true im loosing power, or are they working like stock cam gears? thanks
Old Feb 10, 2005 | 10:10 PM
JDM00SI's Avatar
Default Re: (bigbeasta4)
bump
Old Feb 11, 2005 | 02:57 AM
non-VTEC's Avatar
we can't see the timing marks in those pictures.
how hard is it to look at the marks on the cam gears to see if they are at zero?
and the only way your gonna get the maximum power from them is to dyno tune it......you will never feel the diffrence in cam gear adjustment on stock cams if you try to street tune them.
Old Feb 11, 2005 | 10:14 AM
JDM00SI's Avatar
Default Re: (non-VTEC)
What cams do u perfer? This is a street car, i was thinking maybe some Type R cams or skunk2 cams, no clue....
If i upgrade my cams i will feel a difference right?
Thanks
Old Feb 11, 2005 | 10:34 AM
mmuller's Avatar
Mad Scientist
the only think cam gears can do with stock cams is shift the powerband; assuming your on a dyno you could set them to have a lil. more top end or a lil more mid or a lil more low; you get my drift.
With aftermarket cams is the same, its just that sometimes aftermarket cams are not perfectly centered so you would gain power by setting them where they are supposed to be.
mouab18c1
32
Aug 3, 2011 06:00 PM
93b20z
Sep 3, 2007 12:05 PM
integlstrike1
Aug 13, 2006 07:45 AM
Brewer
Feb 2, 2005 10:48 AM
fastludeh22
Nov 20, 2002 07:38 PM
