damn, still no start
Old Jan 15, 2002 | 10:47 PM
tinkerbell's Avatar
Default damn, still no start - BLACK s.plugs?
JDM B16A wont start.
installed MSD coil and cap cause i thought the coil was bad.
still wont start.
no codes at all
cranks fine (battery is getting low now...) there are sparks at the leads
took s.plugs out - they are BLACK as!
fuel volume seems ok - havent tested fuel pressure yet.
could the injectors be leaking?
please help! any ideas?
t..
[Modified by tinkerbell, 8:10 AM 1/16/2002]
Old Jan 16, 2002 | 12:59 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: damn, still no start - BLACK s.plugs? (tinkerbell)
What car, what ECU.
Did you wire it properly?
More details please.
Old Jan 16, 2002 | 01:35 AM
Lei Siew Long's Avatar
does the starter turn over? have you checked if the fuel pump is functioning correctly? timing?
Old Jan 16, 2002 | 07:04 AM
VTEC4GS's Avatar
sounds like (cylinder) timing is off ... did you put your ign wires on correctly ? did you touch your injector wires ? fuel is not firing at the same time as spark.
Greg
Old Jan 16, 2002 | 01:59 PM
tinkerbell's Avatar
Default Re: damn, still no start - BLACK s.plugs? (vtec4gs)
um, yeah, my bad,
all wires are good, tested for fuel PRESSURE last night,
well, the surge tank was not supplying fuel pressure - only volume, ie it would pump fuel but not pressureised,
turns out to be a internal hose connection inside the surge tank, easy fixed with a new fitting and clamp...(gotta pull it apart though)
so now i got a new MSD setup as well!
thanks for your input guys!
t..
boostmyda
Jul 2, 2010 07:40 PM
ibanender
Nov 16, 2009 06:02 PM
preludepimpin8668
Sep 4, 2007 01:38 PM
EGNA
Jul 12, 2006 03:31 PM
