No oil in oil pan
Old Feb 6, 2005 | 01:31 PM
ek4b18c_r's Avatar
Default No oil in oil pan
Checked the dipstick and there was absolutely no oil on it. It has been less than 3000 miles and there are no apparent leaks, any help would be great, thanks.
Old Feb 6, 2005 | 01:34 PM
92TypeR's Avatar
FSAE
Default Re: No oil in oil pan (ek4b18c_r)
Welcome to the life of owning a C5
For some reason, there are a lot of C5's that burn oil. Perfect compression, but burn 2 quarts every 3k. Just check it every other time you fill up with gas, and you'll be set.
Old Feb 6, 2005 | 01:35 PM
ek4b18c_r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Welcome to the life of owning a C5
For some reason, there are a lot of C5's that burn oil. Perfect compression, but burn 2 quarts every 3k. Just check it every other time you fill up with gas, and you'll be set.</TD></TR></TABLE>
THanks
Old Feb 6, 2005 | 01:44 PM
DutchITR1689's Avatar
https://honda-tech.com/zerothread?id=1135915
Old Feb 6, 2005 | 04:48 PM
Flux's Avatar
Default Re: No oil in oil pan (DutchITR1689)
I didn't realize that the Sinclair C5 would burn so much oil...
Old Feb 6, 2005 | 05:18 PM
icefire069's Avatar
I'm in the same boat but I have somewhat narrowed it down to my dipstick being a little loose which will be fixed soon with jbweld or hondabond.....
zero708970
Mar 29, 2008 02:06 PM
raylude
Mar 4, 2005 06:31 AM
todaspecsi
46
Apr 29, 2004 05:08 PM
IloveNewt
Jan 11, 2004 02:10 PM
Thrillhouse
May 14, 2003 02:27 PM
