performance clutch wearing out clutch master cylinders?
Old Jan 15, 2002 | 07:45 PM
John's Avatar
New User
Default performance clutch wearing out clutch master cylinders?
i recently upgraded to an ACT Xtreme PP w/ SS disc, and immediately blew my master cylinder (the original one w/ 80K on it)... since the clutch is much stiffer, will this wear out the master cylinder quicker?
Old Jan 15, 2002 | 09:08 PM
fixhondas's Avatar
Default Re: performance clutch wearing out clutch master cylinders? (DunReit)
What do you mean blew? no pedal from fluid loss or did you have fluid and no pedal? Clutch masters and slaves are very susceptible to failure if you don't change the fluid Often.
Old Jan 15, 2002 | 09:39 PM
John's Avatar
New User
Default Re: performance clutch wearing out clutch master cylinders? (fixhondas)
well, the fluid is leaking all down behind my dash... clutch still works, but probably for not much longer...
Old Jan 16, 2002 | 12:58 AM
B18C-EJ1
Guest
Posts: n/a
You're going to have to replace it, not a major deal, but my guess is you never changed or cleaned the fluid out.
This should be done about every 50k miles. Fresh fluid keeps the seals nice and makes them last longer. Dirty fluid will contaminate seals and cause them to rupture.
Old Jan 16, 2002 | 12:38 PM
fixhondas's Avatar
Default Re: performance clutch wearing out clutch master cylinders? (B18C-EJ1)
You should really do it every 30k if not sooner (I do mine every oil change). Get a new clutch master from the dealer- and you might go ahead and replace the slave- it WILL be out soon too.
Jaydeep
Dec 1, 2011 05:35 AM
Gomdohree
Apr 24, 2008 06:20 AM
m3 boostin
May 30, 2007 01:20 PM
707EF8
Jul 29, 2006 08:09 PM
94TeGsR
Jan 14, 2003 09:00 AM
