b16 and LS piston heights?
Old Feb 6, 2005 | 07:45 AM
hOndafienD 04's Avatar
Default b16 and LS piston heights?
just need to know these numbers....im trying to do some compression calculations...thanx
Old Feb 6, 2005 | 02:04 PM
hybrid_vtec's Avatar
Default Re: b16 and LS piston heights? (hOndafienD 04)
Check out this link to the Endyne website click here
Old Feb 6, 2005 | 03:04 PM
ok so they are the same height....so lemme ask you a ls block with usdm b16 head, ls, crank, b16 rods and pistons, what would the final compression be? thanx
Old Feb 6, 2005 | 06:03 PM
Default Re: (hOndafienD 04)
they are the same compression height but the dome height is different. The CR should be 11.4:1
Old Feb 6, 2005 | 06:18 PM
yes but the b16 rods are shoter by .104 so piston to deck would change correct?
Old Feb 6, 2005 | 06:23 PM
In an LS, no it shouldn't! Both pistons are the same height, the only thing changing is the dome. The best way to be sure is to measure and be sure.
Old Feb 6, 2005 | 06:35 PM
yeahls pistons are 1.181
b16 pistons are 1.181
ls rods are 5.394
b16 rods are 5.290
pistons are the same height, rods are different lengths, and domes are different...whats am i missing...im just a little confused lol.
Old Feb 6, 2005 | 06:45 PM
LS block is taller I believe.
Old Apr 6, 2005 | 08:39 PM
vegas's Avatar
Piston to deck height is also different cause the ls block is taller. But that isnt gonna matter when it comes to your compression. On a USDM (pr3) b16 piston your compression will be about 10.2/10.1:1, where as on a JDM (p30) b16 piston you will be lookin at 11.4:1. This will also be affected by what headgasket that you use.
-veg
Old Apr 6, 2005 | 08:42 PM
vegas's Avatar
Default Re: (vegas)
Whoops i was wrong, you will be lookin at least 11.4:1 with that setup...
-veg
Griffin@Camtech
Nov 24, 2005 08:14 AM
hOndafienD 04
Feb 10, 2005 04:00 AM
hybridpatient95
Feb 9, 2005 04:45 PM
ls_vtec_b18a1
Oct 13, 2002 12:03 PM
EGHatchy
Jun 24, 2002 08:34 AM
