Bad Idle.....need help
Old Feb 6, 2005 | 06:39 AM
SNaiLCiViCHB's Avatar
Default Bad Idle.....need help
95 cx civic HB, when i start my car the idle is fine but shortly after driving it has a ruff idle (jumps up and down from 800-1500) not sure if its a sensor because i dont get a check engine light. I cleaned out the throttle body...no help. When i shut the car off and restart it...problem goes away. Not sure what it is...suggestions?
Old Feb 6, 2005 | 07:05 AM
Default Re: Bad Idle.....need help (SNaiLCiViCHB)
anyone plz help????
Old Feb 8, 2005 | 02:25 PM
IROSOLO's Avatar
CHECK YOUR IAC MOTOR
Old Feb 8, 2005 | 03:12 PM
VTECaddictB16A's Avatar
you know what the same exact thing is happening to me in my 95 ex with b16a swap, but mine jumps from about 1100 to ...as low as it goes. Sometimes it will kill it but it just fluxuates between that, anyway i had a friend look at it and said that the idle control valve is going bad sooo that might be whats happening to you
Old Feb 8, 2005 | 04:51 PM
turbocivboy85's Avatar
check for vacum leaks and pullthe iac off its underthe trottle body it has a coolant hose and ahose coming off the valve cover when u get the iac off theres a plate with two phillips head screws take that cover off and id uwill seea spring looking the screw it back in the un screw them self just fix my iac two days ago it was doin the same thing
jdm.coupe3234
14
Aug 14, 2013 05:51 PM
codine
Engine Management and Tuning
Mar 11, 2010 10:00 AM
P73typeR
May 5, 2004 06:35 AM
dannyto
May 14, 2003 06:39 PM
Eurasia00
Apr 22, 2002 11:37 AM
