Help; car cut off in middle of road!!!
Old Feb 5, 2005 | 07:59 PM
beaterdriver's Avatar
Default Help; car cut off in middle of road!!!
i just got done filling up my car w/ gas, and i leave. i get in the intersection, i proceed to turn left to go home, when all of a sudden my car cuts off and will not turn back on.
car ran fine before
what in the hell did i do!!!???
any input is appreciated
Old Feb 5, 2005 | 08:00 PM
numbnuts22715's Avatar
has this happened before? maybe you got some bad gas or something?
Old Feb 5, 2005 | 08:01 PM
it has never happened before, i had a half of tank of gas already in it.
i hope its bad gas
Old Feb 5, 2005 | 08:02 PM
komat's Avatar
Default Re: (beaterdriver)
does the motor turn over?
Old Feb 5, 2005 | 08:05 PM
yeah the car turns over like normal, it is just not starting. i made sure my ecu was connected snug, im too pissed off to check the plugs right now and its late, i am just wondering why it did it all of a sudden, in the middle of traffic to make matter worse
Luserkid's Avatar
Default Re: (komat)
Do you hear your fuel pump prime?
STUPID question but i heard stories of this actually happening to people. Did you put desiel in on accident?
Old Feb 5, 2005 | 08:09 PM
the fuel pump didnt prime, i didnt hear a single noise
Old Feb 5, 2005 | 08:16 PM
well i checked all the fuses and my under dash 15amp ecu fuse blew.
Old Feb 5, 2005 | 08:17 PM
change it!
Old Feb 5, 2005 | 08:24 PM
i changed the fuse, it turned on, the fuel pump primed, only ran it for a minute, im too tired to worry about it right now, i just wanna know why my fuse would suddenly blow, that seems a bit strange
Old Feb 5, 2005 | 08:29 PM
maybe something happened and caused a bad ground?? probably stupid, but it could be the case.
Old Feb 7, 2005 | 06:42 PM
i changed the o2 sensor w/ a good used one earlier in the day, maybe the connection wasnt tight?
i dunno
Old Feb 7, 2005 | 06:52 PM
sohcvtec1995's Avatar
if you have a fuel pump kill switch you might want to check that as well. also check the wires going to the pump.
Old Feb 7, 2005 | 07:23 PM
_Spugen_'s Avatar
I turned my car on as well after painting the valve cover and it ran fine then just shut off...I guess Im going to check the fuses too..
Old Feb 8, 2005 | 07:36 AM
i dont have a fuel pump kill switch, i drove around earlier and no fuses blew. maybe it was just a fluke or the fuse was old, or something.
im out of ideas
Old Feb 8, 2005 | 07:48 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a fuel pump kill switch, i drove around earlier and no fuses blew. maybe it was just a fluke or the fuse was old, or something.
im out of ideas</TD></TR></TABLE>
I've seen weirder. I installed my indash TV and then connected a CD changer and it blew my backup fuse. Just keep an extra with you incase it happens agian.
Old Feb 8, 2005 | 08:05 AM
yeah, now i have a whole pack of them
i just dont want to blow a fuse in the middle of an intersection. that is dangerous and scary with cars coming at you
JDMDEEBEE8
Jun 22, 2010 01:09 PM
nonpareil
Dec 25, 2009 06:29 PM
nixin
11
Oct 4, 2007 11:05 AM
dizzyroc88
25
Dec 2, 2006 05:13 AM
trooper0641
21
Jul 24, 2005 01:45 AM
