Need help with idle
Old Feb 5, 2005 | 05:42 PM
ek_b16's Avatar
Default Need help with idle
Car started idleing up and down.. not a vacuam leak but i think it has to do with map.. If i unplug one of the hoses that goes to the back of the intake mini it ildes at 1500 but dont rev anymore.. what do you guys think??? 91 dx with b16a.. also throwing code 9 for the dizzy but i've change it and still the same.. lmk..
Old Feb 5, 2005 | 06:15 PM
4drmadness's Avatar
you will probably find a idle position sensor being bad, or the Idle air control valve. that would be on the backside of the manifold, firewall, that would just need to be unbolted (2 I think) and probably replaced.
I'm sure there is some other thoughts around..good luck..
Old Feb 6, 2005 | 01:53 AM
ek_b16's Avatar
Default Re: (4drmadness)
thanks 4drmadness for the advice but thats not the problem.. I got the code 9 to go away but the idle is still messed up..the idle speed screw is almost all the way out but still doing it.. the hose on the back is out and it stops reving but it will stay idle at 1500 and not lower unless i'm driving.. any other tips??
Old Feb 15, 2005 | 08:53 PM
ek_b16's Avatar
Default Re: (ek_b16)
Still having this idle problem... its kinda messed up cause sometimes when you drive it will go away and idle perfect untill you give it gas then i'll rev.. need help now!!!!!!
Old Feb 19, 2005 | 12:40 PM
ek_b16's Avatar
Nobody here has never had this problem before????
Old Feb 19, 2005 | 03:19 PM
88cerx's Avatar
look into your o2 sensor or it is a vacum leak around master cylinder where it's connected to the break booster, check idleaircontrol valve, and the valve under the trottle body
Old Feb 19, 2005 | 06:44 PM
ek_b16's Avatar
Default Re: (88cerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">look into your o2 sensor or it is a vacum leak around master cylinder where it's connected to the break booster, check idleaircontrol valve, and the valve under the trottle body </TD></TR></TABLE>
I've already check all this.. still no fix... i'm stumped and dont know what else to do???
Old Feb 23, 2005 | 08:43 PM
88cerx's Avatar
explain how you checked all described
Old Feb 23, 2005 | 10:17 PM
Civic138's Avatar
try turning the idle screw down, my car would do this when my idle would be to high.
i just turned it down and reset the ecu and it went away.
Old Mar 2, 2005 | 10:24 PM
ek_b16's Avatar
Default Re: (Civic138)
Heres what i did.. First i changed the iacv... same thing.. second i dont know what this sensor is called but i believe its the idle speed sensor. it has the vaccuam line hooked up to it.. same thing, third i unbolted the twos crews under the tb and turn the bracket as tight as possible and same thing. I even turn the idle speed screw almost all the way out and still the same thing.. At times when its hot outside it will idle fine..but only for a few stop lights then it starts back up again when you give it gas.. it feels like its not even at idle and is truning hard to idle..I drops down to 800rmps then jumps to 1500 please i need this fix.. its starting to really **** me off. Funny thing is at stop lights, some fools think i'm reving on them..
Old Mar 3, 2005 | 09:05 PM
Civic138's Avatar
i know what you mean my car does it sometime to, just try resetting the ecu and see if that help.
i'm telling you everything that i do to make it stop when mine starts to mess up like that.
Old Mar 4, 2005 | 08:15 PM
ek_b16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic138 &raquo;</TD></TR><TR><TD CLASS="quote">i know what you mean my car does it sometime to, just try resetting the ecu and see if that help.
i'm telling you everything that i do to make it stop when mine starts to mess up like that.</TD></TR></TABLE>
Resetting the ecu doesnt fix it..but yeah.. I played with it some more and now it stops reving less but sometimes if you dont give it gas at a stop light it will die.. It wont hold idle.. will idle at 1k then fall and the car dies unless you hold on the gas pedal..???????anyone.......
poppypizza
May 1, 2008 07:47 PM
JSR
May 17, 2006 10:27 PM
Creepshow S60
Aug 29, 2004 06:36 PM
Glocked1
12
Jan 22, 2004 08:13 PM
