Timing gun question - JDM h22a
Old Feb 5, 2005 | 05:22 PM
metalgears's Avatar
Default Timing gun question - JDM h22a
Where are the degrees marking to set the timing?
I am using the v window in the block near the tranny.
Old Feb 5, 2005 | 05:26 PM
blackdelslo's Avatar
Default Re: Timing gun question - JDM h22a (metalgears)
pull the rubber plug off the tranny and they are on the flywheel.
Old Feb 5, 2005 | 05:27 PM
Hawkze_2.3's Avatar
The red mark on the flywheel is 15 degrees.
Old Feb 5, 2005 | 08:20 PM
superturboprelude's Avatar
Default Re: Timing gun question - JDM h22a (Hawkze_2.3)
well i dont see a red mark on mine i see a line with a 15 on it is that it? i have a h22a jdm 1995
Old Feb 5, 2005 | 10:51 PM
MackDad's Avatar
Default Re: Timing gun question - JDM h22a (superjunprelude)
Make sure you bridge the blue service connector before you adjust timing...
Old Feb 5, 2005 | 11:48 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude &raquo;</TD></TR><TR><TD CLASS="quote">well i dont see a red mark on mine i see a line with a 15 on it is that it? i have a h22a jdm 1995</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackDad &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you bridge the blue service connector before you adjust timing...</TD></TR></TABLE>
Do this first, then set the gun to 0 degrees and look for the
line with the 15 mark to be even with the mark on the block.
Or you can set the gun to 15deg and look for the tdc mark.
DarkBB4
Jan 7, 2012 11:07 PM
pcguy760
May 21, 2007 07:53 AM
jdm00civicex
Sep 27, 2006 09:00 PM
User 5426
Jan 14, 2004 02:36 PM
Timmayeg
Sep 25, 2002 08:55 PM
