Charging system HELP MY HYBRID!!!!!!
Old Feb 5, 2005 | 03:46 PM
HybridHatchC1's Avatar
Default Charging system HELP MY HYBRID!!!!!!
Yea so this damn problem has got me irritated to all hell... I have a charging system problem...The system wont charge. i can manually charge the battery but once its done the car dies. I have a battery/charging system meter it shows that my car isnt charging.(only showing 12v), and underload when testing the alternator it starts to die. I know a honda will over load the alternator and shut down if the batttery is bad, but thats not the case either. Its Def not the alternator Nor the battery they both were checked and replaced twice as well as the battery terminals... Does anyone have any suggestions? Has this happend to anyone before?
Old Feb 5, 2005 | 03:53 PM
5thGenCivicKid's Avatar
Default Re: Charging system HELP MY HYBRID!!!!!! (HybridHatchC1)
check the wire from the fuse box to the alternator it could be the harness to that is bad that happen to me
look at you fuse box under the hood it is the wire that is white with a red strip follow it to the alternator im pretty sure that the one
Old Feb 6, 2005 | 08:06 AM
Default Re: Charging system HELP MY HYBRID!!!!!! (5thGenCivicKid)
bump
Old Feb 6, 2005 | 08:56 AM
hatchi's Avatar
check fuses and wiring. did you do anything before this started happening?
Old Feb 7, 2005 | 12:33 PM
Default Re: Charging system HELP MY HYBRID!!!!!! (hatchi)
ummm... i did a dash swap(GSR) but it was working fine even after that for like 2-3months
Old Feb 8, 2005 | 04:26 AM
EE_Chris's Avatar
Hey bro - throw me your e-mail addy and I'll send you a .pdf of how Honda's charging system works along with diagnosis.
I had the link for it, but its broken now - but I did save the file to my harddrive.
If anyone else wants it too, let me know.
Speed--Freak
15
Jan 5, 2022 05:22 AM
Lance Baker
Honda CR-V & Element
Dec 5, 2021 06:55 PM
eggie75
Mar 25, 2010 04:37 PM
Annihilator
Oct 14, 2009 04:55 PM
NIGHTRIDER27
Aug 20, 2006 11:06 AM
