440S RUNing @ 100% all the time
Old Feb 5, 2005 | 02:40 PM
turbo_b16_ex's Avatar
Default 440S RUNing @ 100% all the time
hey i tried out dsm injectors on the car and it run fast but it get **** for mileage. i know hondata is the best way to fix it but is there any way else to do it for cheap other than vafc? i had that resistor box hooked up to.
Old Feb 5, 2005 | 02:44 PM
jlacoy82's Avatar
71.192.16.183
Default Re: 440S RUNing @ 100% all the time (turbo_b16_ex)
Shouldnt you have thought about fuel management BEFORE you slapped them in? Especially seeing as you seem to know you were going to need some sort of management?
Um.........
-Hondata
-Uberdata
-Vafc/safc
-EMS
-Power FC
Old Feb 5, 2005 | 04:15 PM
Soccerking3000's Avatar
Default Re: 440S RUNing @ 100% all the time (jlacoy82)
umm uberdata, for 130 bucks you could have all the options of hondata and tune it yourself...
Old Feb 6, 2005 | 07:54 AM
whats required for uberdata? a p28 ecu and sumtin else i think. Ive seen the maps that you can make and control for it, but i wouldnt know how to use it.
Old Feb 6, 2005 | 08:10 AM
Luserkid's Avatar
Default Re: (turbo_b16_ex)
You went from small injectors to big injectors. What did you think was goign to happen with your gas mileage without tuning?
Old Feb 6, 2005 | 09:51 AM
damn i swear im getting sick of these people on here who just say some ******* **** to say some ******* ****. Shut the **** up unless u got something that may be helpful. thank you
Old Feb 6, 2005 | 09:54 AM
ralphie14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">whats required for uberdata? a p28 ecu and sumtin else i think. Ive seen the maps that you can make and control for it, but i wouldnt know how to use it.</TD></TR></TABLE>
Not unless you have a Non-VTEC car... then you will need a P75, or P06. Unless you want to somehow remove the VTEC part of the ECU
Old Feb 6, 2005 | 10:00 AM
eK9aT10pSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You went from small injectors to big injectors. What did you think was goign to happen with your gas mileage without tuning?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">damn i swear im getting sick of these people on here who just say some ******* **** to say some ******* ****. Shut the **** up unless u got something that may be helpful. thank you </TD></TR></TABLE>
dont oyu think its your own fault/ignorance that you didnt do the research first ? i wouldnt get mad at others stating the obvious. easiest way is to get a S-AFC and just set it around -35 as a base then dyno tune it. gas milage will go up.
Old Feb 6, 2005 | 10:04 AM
i knew the mileage would deacrease but not to the extent of 6 miles per galon. ive never heard of it being that bad with dsms. they just ssay it doesnt get very good gas mileage for a honda.
Old Feb 6, 2005 | 10:17 AM
well think about it at 3000 rpm your car stock is at about 40% duty cycle (235cc injectors), so you are using the injectors as 94cc at 100% (for values sake), now take 440 100% thats 5 times as much fuel than you need, so you go from 32 divided by 5 and you get around 6.4mpg... simple math
edit: i just looked it up and actually at 3000rpm you are 20% duty cycle so in reality you should be around 4 mpg....
Old Feb 6, 2005 | 11:21 AM
makes sense im not very good with numbers
FragSyndrome
Mar 14, 2004 09:01 PM
ActiveAero
Aug 20, 2003 09:09 AM
mike1114
Jun 17, 2003 09:53 PM
PressurizedSi
Jan 9, 2003 10:22 PM
boomslang
Aug 29, 2001 06:50 PM
