damaged valve guides?
Old Feb 5, 2005 | 09:57 AM
bjfisher's Avatar
Default damaged valve guides?
i'm looking at buying this h22 head off of ebay, the guy said that the exhaust valves are bent, and that is the only problem....my question is, if i got new valves, is that really all i would need to do in order to fix it?i'm kinda in a hurry, bc another head i'm looking at is over tom.
i belive, that the worse case scenario would be the valve guides being damaged....if so, then what would need to be done besides replacing valves(if there wasnt any guide damage)??
heres a link to the ebay ad
http://cgi.ebay.com/ebaymotors...=WDVW
Old Feb 5, 2005 | 10:36 AM
GDM Z28's Avatar
Default Re: damaged valve guides? (bjfisher)
[QUOTE=bjfisher]i'm looking at buying this h22 head off of ebay, the guy said that the exhaust valves are bent, and that is the only problem....my question is, if i got new valves, is that really all i would need to do in order to fix it?i'm kinda in a hurry, bc another head i'm looking at is over tom.
http://cgi.ebay.com/ebaymotors...=WDVW[/QUOTE]
if the head is that cheap just buy it and buy a set of valves from someone....a machine shop down here charges $7.50 a guide for ne ones that are bad.....unless they are all bad the head should be a good deal.
Old Feb 5, 2005 | 10:49 AM
bjfisher's Avatar
ok cool, so it sounds to that even if the guides are damaged, it is a relatively cheap repair plus some valves....?
Old Feb 5, 2005 | 12:25 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (bjfisher)
Well, do you have pics of the head? Its a different story if the valves bent and dinged up other stuff in the head. I'd say as long as its just the bent valves and the valve seats didnt get raped, go for it. Just get the valves/guides/seals replaced and rock it.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
SirRevvs
Oct 14, 2010 10:32 AM
clem kevin
Feb 26, 2009 01:09 AM
ITRiWISH
May 15, 2008 03:55 AM
jdmjeff
Dec 21, 2005 02:18 PM
