Check Engine Light came on.... Code 7
Old Feb 5, 2005 | 08:40 AM
surferchad122's Avatar
Default Check Engine Light came on.... Code 7
I just got a check engine light last night after picking up my new (used) car from someone off of here. It is throwing a code 7, Throttle position sensor...
It's a B16b in a 99 DX hatchback, what should I do to fix it, it's really annoying being in LIMP mode.. No VTEC, idles at 1500... etc.
Any help is GREATLY appreciated.
Old Feb 5, 2005 | 09:16 AM
egsleepercivic's Avatar
check the voltage of the tps, should be .5v closed and 4.5v wide open, on jdm motors its pretty easy to adjust or replace the tps
to adjust loosen the bolts on the TPS and turn until you get the above voltages, if you can not get it to spec replace it. you can probably get a used cheap in the classifieds on here or JDM engine importer.
good luck.....hope this helps
Djmontiel
Feb 16, 2016 01:30 AM
importdude2000
Jul 17, 2004 12:53 PM
bokguay
Mar 19, 2003 10:11 AM
