can no speedo cable cause
Old Feb 5, 2005 | 07:54 AM
dirtracer's Avatar
Default can no speedo cable cause
if you don't have your speedo cable in the speed sensor will it cause the fluid to spray up to the top of the engine? I did a swap broke the speedo cable went for a test drive & it threw a code for speed sensor. checked under the hood and oil on the back top mount and such, could it be i don't have my axle shaft in far enough or is it the fluid from the speed sensor. i looked but i haven't got under there yet any input would be a help. TIA 89 coupe
Old Feb 5, 2005 | 03:07 PM
4DRPIMPIN's Avatar
If your refering to fluid coming out of the transmission. Yes that can happen. Replace the sensor and your leak should go away unless its coming from somewhere else, like higher up on the block.
hoga113
Mar 8, 2013 04:32 PM
rolledthatho
15
Jan 26, 2011 07:52 PM
nwstreets
Northwest (Sales)
Nov 10, 2010 08:05 PM
dirtracer
Feb 9, 2005 06:36 AM
CimorelliCRX
Jan 4, 2002 11:00 AM
