is it hard to bleed the clutch?
Old Feb 4, 2005 | 10:08 PM
biggsac's Avatar
Default is it hard to bleed the clutch?
my clutch i think has some air in the system and i need to bleed it but havent done on this car before. was just wondering how difficult it is and what i'd need
Old Feb 5, 2005 | 06:19 AM
hondadude's Avatar
Default Re: is it hard to bleed the clutch? (biggsac)
Did you check the fluid level ? If the fluid is low you might want to check under the dash to see if the clutch master is leaking, or check the slave for leaks.
Old Feb 5, 2005 | 08:41 AM
wed3k's Avatar
bleeding takes about 15-30 minutes depending how fast you can pump the pedal...you will need two people.
Old Feb 5, 2005 | 03:20 PM
4DRPIMPIN's Avatar
Default Re: (wed3k)
Yeah easy. You'll need a 8mm wrench and some hose (to fit over the bleeder bolt), a jar to put your fluid in, and a friend to pump the pedal. Just make sure when your bleeding it to constantly keep filling the cylinder so it doesn't run empty.
JoshV1288
19
Jan 26, 2013 02:41 AM
starquestchris
Mar 23, 2010 10:25 AM
honda_racing101
Sep 18, 2007 06:53 PM
carblegal
Mar 24, 2003 08:24 PM
PatrickGSR94
Dec 8, 2002 06:36 PM
