wheel bearing problem
Old Feb 4, 2005 | 06:18 PM
vjace's Avatar
Default wheel bearing problem
i know for a fact that my wheel bearing went bad and i have been ignoring it for a while and now im sick of the sound and stuff so i need to change it. i have a 96 integ se im not sure if i need to take out the whole knuckle and have it pressed out or i can change it my self. and would i need a new hub since i been driving on a bad bearing for the longest time ? i drove like 13000 miles so far on a bad bearing i should have fixed it right away that was my mistake any input would help thanx
Old Feb 8, 2005 | 04:30 PM
supdawg2's Avatar
Default Re: wheel bearing problem (vjace)
I think the hub is okay. You will have to take out the knuckle, although I hear there is a tool which some shops have which press the bearing out without having to take the knuckle out. You'll need to take the knuckle off, press the hub out, take out the front and back C-clips holding the bearing in, then press the bearing out. Reverse the order for installation.
Here's the only problem. I'm trying to find a shop that will press the bearing and hub out for me and press the new bearing in. All the shops I'm calling are saying they can't do that due to liability reasons, so I need to drive the whole car in and let them do all the work. That's great, but that also costs like 4 times as much.
Anyways, good luck.
Old Feb 9, 2005 | 03:44 PM
vjace's Avatar
Default Re: wheel bearing problem (supdawg2)
thats what i was worried about
i never paid some one else to fix my car thanks for your help im going to ask a few shops around here and ask them if they can do it for me if i took out the knuckle
RacerTim
Sep 10, 2010 05:44 PM
alexb18c1
Sep 24, 2008 05:25 PM
CivicVX94
Oct 15, 2007 05:42 PM
petergriffen
Aug 11, 2006 08:44 PM
yung98gsr
Feb 18, 2005 09:28 AM
