New to EFs, how the hell do I change tranny fluid?
Old Feb 3, 2005 | 10:22 PM
trooper0641's Avatar
Default New to EFs, how the hell do I change tranny fluid?
I have a CRX Si...I cannot find a hole or anything like that on my si tranny to put in the fluid.
Old Feb 3, 2005 | 10:30 PM
FalkenSiR's Avatar
Default Re: New to EFs, how the hell do I change tranny fluid? (trooper0641)
There is a bolt on the back side of the tranny (side facing passenger). Unbolt it, and then you can refill the tranny. Once you see that one, you might spot the draing plug (bolt) but it's kinda more visible from the bottom.
Old Feb 3, 2005 | 10:31 PM
hndagirl's Avatar
Default Re: New to EFs, how the hell do I change tranny fluid? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">There is a bolt on the back side of the tranny (side facing passenger). Unbolt it, and then you can refill the tranny. Once you see that one, you might spot the draing plug (bolt) but it's kinda more visible from the bottom.</TD></TR></TABLE>
Old Feb 3, 2005 | 10:34 PM
ridexstraight's Avatar
Default Re: New to EFs, how the hell do I change tranny fluid? (hndagirl)
https://honda-tech.com/zerothread?id=1135783
check this post out, it'll tell u evrything, pics and all
Old Feb 4, 2005 | 03:36 AM
StorminMatt's Avatar
You also need a funnel with a long tube to fill your transmission. There is NO WAY to get the nipple on the bottle to fit in that hole.
Old Feb 4, 2005 | 04:15 AM
MENACE's Avatar
Default Re: New to EFs, how the hell do I change tranny fluid? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">You also need a funnel with a long tube to fill your transmission. There is NO WAY to get the nipple on the bottle to fit in that hole.</TD></TR></TABLE>
Or he can Unscrew his backup Switch on the top of the Tranny. Then he can fill it with a shorter funel thats how i did it. Just leave the drain plug out and fill the transmission till it come out the hole.
spintboy
Jan 20, 2008 09:24 PM
.one lane
May 2, 2006 05:38 AM
H22A4Me
Jan 27, 2006 07:55 PM
vmm
Jun 25, 2004 08:54 PM
CrXstEalin
Jan 12, 2004 11:01 AM
