Compression Test Results - my first build so im stoked!
258-265-260-268
It was 225 on all four, just 2000km after the rebuild, now 40k later its gone up?
BTW - it was a "dry" comp test.
Comments...
Comments...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">carbon build up raises compression. looks good
I would think it has more to due with the rings seating over the 2000 km's you've driven. Nonetheless, the numbers look good.
</TD></TR></TABLE>I would think it has more to due with the rings seating over the 2000 km's you've driven. Nonetheless, the numbers look good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizic »</TD></TR><TR><TD CLASS="quote">258-265-260-268
Comments...</TD></TR></TABLE>
Its from the rings seating. Thats what its supposed to. Although, those rings should have pretty much been seated by 2,000km, if you broke it in right.
What setup is this?
What setup is this?
B18c jdm gsr w/:
usdm rods/pistons
milled .025 head
str block guard
crower ss valves .002 oversized
mild p&p
did everything myself so im happy it works.
Still to hit the dyno so no real #'s yet.
usdm rods/pistons
milled .025 head
str block guard
mild p&p
aj345
Jun 2, 2013 07:58 PM
