valvetrain?
Old Feb 3, 2005 | 08:52 PM
allmotorteg_96's Avatar
Default valvetrain?
i am running ls/vtec and i am looking at the bc3+ or the bc4s my setup will be
b16 head
b18 block
ctr pistons .25 OS
vtec water and oil pump
act 8.8 lbs fly wheel
act clucth
itr tranny
twm itbs
my ? is if i buy itr springs and retainers will that be good enough to rev bc3+ or the bc4s to 8500 rpms.
thanks bill
Old Feb 4, 2005 | 10:24 AM
Default Re: valvetrain? (allmotorteg_96)
bump
Old Feb 4, 2005 | 04:16 PM
ttt
Old Feb 4, 2005 | 04:29 PM
BigHeadKid's Avatar
you would have to look at the lift and duration of your new cams to see if they are compatible with itr equipment. som,etimes they are if you dont go past stock redline; sometimes theyr not. ie spring rate, seat pressure, that sort of thing
Old Feb 4, 2005 | 07:49 PM
Default Re: valvetrain? (BigHeadKid)
thanks anyone else have any info
Old Feb 4, 2005 | 08:41 PM
SpdFrk's Avatar
No, don't use ITR valvetrian with BC3's or 4's. Me personaly, i like REV or RM valvetrian. Can't go wrong with either, both proven parts.
Old Feb 5, 2005 | 02:00 AM
thevanitygroup's Avatar
Default Re: valvetrain? (SpdFrk)
NOTE >>> You should NOT take you LS/V passed 8500k rpms without a girdle. That being said, I'm positive that the BC3+'s would be a better match for your setup. Another recommendation would be B16 P30 oversize pistons instead of the CTR pistons you plan on using. There are a variety of reasons why but I like the small dome for more equal combustion and better in flow. That all ties into the rods modifications for fit CTR's and none modifications required for B16 P30 pistons too.
For BC3+'s the Type R springs are perfect because you dont really make power passed 8500k rpms and the Type R springs can definatly handle that. The real problem would be the retainer and even thats not a problem but more insurance in my book.
For the BC4's your definatly going to be making power passed 8500k rpms so I would invest in a entire valve train. I personally like Omnipower, RM and Portflow. Which ever you choose, theres no going wrong. KTELLER.COM has great deals on Omni and Rocket valve trains right now too.
Old Feb 17, 2005 | 05:29 AM
BigHeadKid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">No, don't use ITR valvetrian with BC3's or 4's. Me personaly, i like REV or RM valvetrian. Can't go wrong with either, both proven parts. </TD></TR></TABLE>
bump! rev/rm is the ****!
Old Feb 17, 2005 | 06:23 AM
mmuller's Avatar
Mad Scientist
Default Re: valvetrain? (thevanitygroup)
rev limit is one of the playing factors in the valve springs that you choose.
it is not the same to rev a itr cam to 8500 than a bc3 to 8500..
you guys forget about lift and ramp of the cams.
Old Feb 18, 2005 | 10:53 AM
Default Re: valvetrain? (mmuller)
well do i need to change out my lma's with bc3+'s or just the valve spring and retainers
Old Feb 18, 2005 | 01:35 PM
bump it
Old Feb 19, 2005 | 02:31 PM
upity
Old Feb 19, 2005 | 04:29 PM
Ninja Mike's Avatar
Personally, I would use the ITRs with the BC3+. I would use RM's gen 1 springs and gen 2 retainers with BC4. However, since you are not sure which cam to use and you are only looking to rev to 8500, then I'd confide in Rocket himself. He could set you up with a mismatch between his gen 1 and 2 components to accommodate the best of both worlds, BC3+ & BC4 to an 8500rpm red line.
Omniman for valves; will work with Rocket's valvetrain.
My $0.02
nuns_have_no_fun
Jan 4, 2007 06:57 PM
theslugbug
10
Oct 27, 2003 03:30 PM
hatchdrvr
Aug 8, 2003 04:17 PM
hatchdrvr
Aug 8, 2003 04:08 PM
hatchdrvr
Aug 8, 2003 12:51 PM
