h22a4 brearings
Old Feb 3, 2005 | 07:28 PM
cal_'s Avatar
Default h22a4 brearings
well i took my block to a machine shop to get the align bore checked and to have a few other things done. well the machine shop lost the bearings and now i have no idea what size i need to get. did honda ever put a marking on the block to say what size bearings they put in the block? ive found a series of 4's on the block but im not sure if that means anything, and i also found numbers and letters on the crank also, does that mean anything about bearing sizes. also the block is a 99, the one with different main journal sizing. any help would be great.
Old Feb 3, 2005 | 07:36 PM
prelittlelude's Avatar
Default Re: h22a4 brearings (gsr778)
yes honda put markings on the block and on the crank.
there are two sets of markings on the crank one for the rod bearings and one for the main bearings. the markings on the crank with the markings on the block coencide to a chart that you can work out the correct sizes. im not at home or i would bust open my helms and tell you.
but the markings should be on the bottom corner of the block. and id on't remember where they are on the crank. ill have to post up more infromation tomorrow
Old Feb 3, 2005 | 07:39 PM
cal_'s Avatar
Default Re: h22a4 brearings (prelittlelude)
Old Feb 3, 2005 | 08:33 PM
satan_srv's Avatar
get a helms manual.
seriously. you shouldn't guess this kind of stuff or just take what you get on the internet.
Old Feb 4, 2005 | 09:52 AM
cal_'s Avatar
Default Re: h22a4 brearings (satan_srv)
i just ordered one yesterday. but in the meantime im just curious.
Old Feb 4, 2005 | 01:05 PM
satan_srv's Avatar
Well it's a grid...letters on block block by numbers on crank = bearing colours
Old Feb 4, 2005 | 05:47 PM
cal_'s Avatar
so what do all 4's on the block and all 4's and one 5 on crank = to bearing colors?
Old Feb 5, 2005 | 01:47 PM
cal_'s Avatar
heres some pics of my crank and block with the numbers. if some one could tell me what color bearings i need based on the numbers and letters.
Old Feb 5, 2005 | 05:44 PM
Fly1865's Avatar
pulley to flywheel
brown, black/brown, green, brown, bown/black
Old Feb 6, 2005 | 12:32 AM
cal_'s Avatar
Default Re: h22a4 brearings (Fly1865)
SWEET!!! thanks a ton fly!!!
mrbsponge
May 3, 2006 07:54 AM
Pandahatch
Feb 26, 2006 10:08 AM
VanHonda
May 2, 2004 11:39 AM
Jared
Jun 24, 2001 09:53 AM
