Ball Bearing, is it worth the money?
Old Feb 3, 2005 | 05:41 PM
97ls's Avatar
Default Ball Bearing, is it worth the money?
I am planning on buying the Gen 3 Drag Turbo Kit or the Stage 2 Rev Hard Turbo Kit. I was wondering if there is a big difference between the two and if anyone had had experience with these turbo kits? I am also wondering if there is a big difference in spool up with a ball bearing turbo? I just want to know if it is worth the extra money. Thanks.
Old Feb 3, 2005 | 06:13 PM
gsr-2nr's Avatar
Default Re: Ball Bearing, is it worth the money? (97ls)
ball bearing will spool up faster than the conventional bushing turbo. It is more of what you are looking for if you want the turbo to kick in asap away then get bearing. if ur just looking for everyday i can be patient driving then get the normal. also take into consideration the cost a ball bearing will cost significantly more and in some cases you cant really rebuild a bb turbo abd if if can it costs a shitload more than regular. try searching for people with the same question and post something in the forced induction forum as well
Old Feb 3, 2005 | 06:14 PM
Lord Helmet's Avatar
I asked that question a few years back at a SEMA show towards a spokesman for Garrett Turbos. He showed me a traditional turbo(journal bearing type) cut out to show the turbine blades and a ball bearing type. When I spun the regular bearing and then spun the ball bearing type, I notice how fast the ball bearing blades move with so little effort compared to the journal bearing type turbo. So to answer your question if you don't mine a little turbo lag the journal bearing aka regular turbo type will be find since a lot of car manufacturer has used them without major problems.
Now if you like little to no lag and can afford the extra money for the ball bearing assuming you have a big turbo, then this will be very beneficial for you. But if you have a little turbo like a Greddy 16G or 18G it would be a waste of money.
Old Feb 3, 2005 | 06:31 PM
xbB's Avatar
xbB
Default Re: Ball Bearing, is it worth the money? (sleeperciv)
ball bearing all the way
Old Feb 3, 2005 | 07:29 PM
97ls's Avatar
Does anyone know how much faster the ball bearing turbo will spool up (in rpms) on a t3/t4 than the regular turbo? Does anyone also have experience with these kits and know how well they spool up?
Old Feb 3, 2005 | 07:46 PM
TurboGS-R's Avatar
Default Re: (97ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ls &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know how much faster the ball bearing turbo will spool up (in rpms) on a t3/t4 than the regular turbo? Does anyone also have experience with these kits and know how well they spool up?</TD></TR></TABLE>
Yes, the DRAG kit is ball bearing, right? My T3/T04 hits full boost at about 4500 rpms and begins boost at about 2500 I think.
Get a BALL BEARING turbo please unless you enjoy extra lag. Even 1000 rpms of lag throughout your 3rd gear will slow you down quite a bit.
Old Feb 3, 2005 | 07:52 PM
97ls's Avatar
Default Re: (TurboGS-R)
The drag turbo kit from turbo-kits.com is not ball bearing. You can buy the ball bearing turbo but it is $650 more.
http://www.turbo-kits.com/integra_turbo_kits.html
Thank you all for your info.
Old Feb 3, 2005 | 09:30 PM
shermanyang's Avatar
Default Re: (97ls)
i honestly think that if you're gonna get a ball bearing turbo you should decide what size it should be and not let DRAG decide/limit the choices for you. i would just get the regular drag kit and sell that turbo and use the money to buy a GT ball bearing turbo.
IMO though, bb turbos are too rich for my blood. i'd rather use my money towards a propane injection kit.
Old Feb 4, 2005 | 10:23 PM
robboostgsr's Avatar
k ball bearing turbos spool up faster,,and no turbo lag, also i have heard they need less work, and last longer
Old Feb 6, 2005 | 07:40 PM
torqueless's Avatar
Default Re: (robboostgsr)
i dont understand the difference between them other than the ball bearing spools faster, but if you were to look at both of them side by side can you tell wich is wich? can someone post a pic of what the ball bearing looks like??
Old Feb 7, 2005 | 02:22 PM
torqueless's Avatar
Default Re: (torqueless)
bump
Old Feb 7, 2005 | 02:34 PM
JonnySBeee...'s Avatar
build your own turbo kit mang.... http://www.importparts.com then go under forced induction, then click custom b-series. there you go, choose peice by peice
Old Feb 8, 2005 | 01:28 PM
NRN GT4's Avatar
Default Re: (shermanyang)
Propane injection? I thought that was only for Deisel?
prelude beast
Nov 2, 2003 11:07 AM
mojord
Apr 29, 2002 10:28 AM
Markaccord95
Feb 6, 2002 08:57 PM
HXMan
Nov 19, 2001 12:03 AM
JSpecwest
Aug 30, 2001 06:22 PM
