Rear coilovers in the front?
Old Feb 3, 2005 | 05:37 PM
Outkast95LS's Avatar
Default Rear coilovers in the front?
This may sound a bit peculiar, but i have a set of rear skunk2 coilovers (spring rates: 400ft/lb i believe). My car is currently on ground control coilovers (350f/250r) I was wondering if i could run the rear skunk2 coilovers in the front, and then swap the front GC coilovers in the rear. This way, my spring rates would be 400f/350r.
Any insight would be greatly appreciated. Thanks!
Old Feb 3, 2005 | 06:40 PM
SYTFU Tommy.'s Avatar
Default Re: Rear coilovers in the front? (Nine5IntegraLS)
might sit a little higher since the rear springs are higher than the front
Old Feb 3, 2005 | 07:05 PM
Default Re: Rear coilovers in the front? (tngay)
i dont mind the height, i'll just play around with the perch until i find the right height setting. I'm just worried that the springs wont fit.
Old Feb 3, 2005 | 08:32 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Front and back was pretty much the same when i had my springs on and off, It should work just fine.
Old Feb 3, 2005 | 08:52 PM
Code Blue's Avatar
Default Re: Rear coilovers in the front? (FlatBlackTeg)
the differences are the springs.
Old Feb 3, 2005 | 08:54 PM
Default Re: Rear coilovers in the front? (Code Blue)
What do u mean the differences are the springs? Meaning the length of it? Or do you mean the spring rates? (which i already know)
Old Feb 3, 2005 | 09:16 PM
Hype-R Stalker
Rear springs will probably be a bit softer, maybe thats what he meant?
Old Feb 3, 2005 | 11:50 PM
Oh, but I provided the spring rates for both coilovers.
09civicsi01826
Honda Civic (2006 - 2015)
May 9, 2011 06:35 PM
jerm__
Honda Civic (2001 - 2005)
23
Apr 30, 2010 06:20 PM
strsi
Suspension & Brakes
Jan 5, 2008 10:55 PM
ware
Suspension & Brakes
14
Aug 23, 2007 05:49 PM
Outkast95LS
Suspension & Brakes
Feb 6, 2005 02:24 AM
