B18C5 All motor build up
Old Feb 3, 2005 | 07:12 AM
92civicman's Avatar
Default B18C5 All motor build up
Can someone help me do an all motor build up on a 96-97 B18C5. All help will be greatly appreicated.
Old Feb 3, 2005 | 08:05 AM
No_Fear's Avatar
Default Re: B18C5 All motor build up (92civicman)
how much you can spend ?
and it will be a daily car or a drag ?
Old Feb 3, 2005 | 08:07 AM
92civicman's Avatar
Default Re: B18C5 All motor build up (No_Fear)
it will be daily driven, i will spend as much as it takes
Old Feb 3, 2005 | 09:39 AM
No_Fear's Avatar
SKUNK2 STAGE II CAMSHAFT,SPOON OR MUGEN HEAD GASKET,AEM CAI AND E-MANAGE is a cheap and nice setup.
if you want more
bore it to 2.0L
whats your goal?
Modified by No_Fear at 6:52 PM 2/3/2005
Old Feb 3, 2005 | 11:07 AM
juntuned's Avatar
buy my pistons $500. i wouldnt go that much above 12:1 as anyone will tell you would be the safe limit for streetability. (maximize your compression without paying to resleeve your block, unless that is what you want to do)
there are a bizillion different combinations u could use, I wouldnt use skunk 2's but thats just my preference.
Old Feb 3, 2005 | 12:29 PM
ITRacer121's Avatar
I used the BC3+ which were alot of fun to drive around town due to all the torque but the peak WHP wasnt all that great.
I now have the BLOX B's and waiting for results
Old Feb 3, 2005 | 12:53 PM
92civicman's Avatar
ok how much do you recomend boring it out to ? i was thinking about getting the Corwer 2.26L stroker kit form inlinefour.com, and putting indivduial throttle bodies. Does that sound good to you? i mean i am also going to put like exhaust adn all of that stuff, but just let me know what you think.
Old Feb 3, 2005 | 02:27 PM
thevanitygroup's Avatar
Just by how you sound. Dont spend $1 until you read information on this board daily for 6 months. Its not just about buying anything and throwing it on. Theres a science to it. Trust me. My .02
Old Feb 3, 2005 | 02:43 PM
Scotty B's Avatar
Read a bit ..... do the knowledge. Before you spend a grip of cash
Old Feb 3, 2005 | 02:56 PM
Bradstard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicman &raquo;</TD></TR><TR><TD CLASS="quote">ok how much do you recomend boring it out to ? i was thinking about getting the Corwer 2.26L stroker kit form inlinefour.com, and putting indivduial throttle bodies. Does that sound good to you? i mean i am also going to put like exhaust adn all of that stuff, but just let me know what you think. </TD></TR></TABLE>
As a daily driver, I wouldn't go anymore than 85mm. That is what I am running on my B18C5 also. You can stroke the motor all you want but the longer the stroke the less you'll be able to rev it. I'm also running an 89mm LS crank. I would recommend that you READ READ READ and research everything before you buy it.
Old Feb 3, 2005 | 03:42 PM
yaya's Avatar
ctr pistons
jun3 cams
cam gears
valve springs
330's
fuel pump
fpr
aebs im
65mm tb
lovefab header
s200
toda timing belt
hotter plugs....idunno
ORRRRRRRR instead of asking a bunch of strangers what to buy for your precious c5, do some research. i would throw ctr pistons in alone and that would be coo with tuning
thatwhiteguy
Jan 22, 2007 10:33 AM
jdmsijdm
Mar 2, 2005 09:36 PM
GsrJasonIII
Dec 23, 2004 02:31 PM
B18C_EJ8
13
Jul 2, 2003 11:33 PM
x James Bond x
Oct 6, 2002 09:01 PM
