Compression question
Hey guys can anyone help me with a compression ratio question, I have a B20b block with stock rods, JE 10.5 pistons, OEM headgasket,and PR3-4 head. I found this link,http://www.c-speedracing.com/h...c.php ,on another site and filled it out but not sure if I did it right, the only thing I'm not sure about is piston dome displacment and stroke I put 10.5 for displacment and left stroke stock, did I do it right??? if anyone could help I would just like to know what my comp. is thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM JEFFREY »</TD></TR><TR><TD CLASS="quote"> your comp is 10.405047497889803</TD></TR></TABLE>
really cuzz on the link it says 13.1, not saying your wrong but why is it that????
10.5 is not the displacement height........CTR's are only 8.6 cc. If you ordered a 10.5 cr piston and you have a stock head then your CR will be around 10.5. Good Luck!!!
ok thats what i wasn't sure of what the displacment of my JE 10.5 pistons cuzz on the site it askes for the diss. and i don't know that, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">Piston dome displacement is -1.7cc.
Glenn</TD></TR></TABLE>
so this is the dome dis. for my JE 10.5 comp. pistons??? if so thanks for the help
If the compression height of the B20 pistons and those JE's are different then that CR number is wrong. Does anyone know the compression heights for those JE's and the B20 pistons?
I don't think so...............If the dome on the piston rises It will be positive not negative.
Maybe your saying the dome takes away 1.7cc of the combustion chamber volume????
allmtrdc4
Jul 17, 2004 06:58 PM
Se-rv-Tak
Dec 11, 2003 06:10 PM
