Will 60-1 turbo clear AC on teg?
I drove the integra this entire last summer with no A/C
I just never turned it on. It made the car bog for some reason when starting from rest.. ??
CRX does not have A/C either and I drove that through august in the heat
Dustin
I just never turned it on. It made the car bog for some reason when starting from rest.. ??CRX does not have A/C either and I drove that through august in the heat
Dustin
well, i prefer comfort over anything. But to get more power...t3/t4 is not going to get me anywhere...and 60-1 will hit my ac
DOPE! Any other choices out there?
Jeff-
Jeff-
You would need a new exh manifold with the 60-1. Why not do T3/T4 Stage V on the exhaust and a 60 trim on the intake? Stage V flows exhaust like a T4 as it has T4 internals and the 60 trim puffs a grip of air. This set up s/b good for 500 whp which is killer on the street. I made 440 with a Stage III and 54 trim. This should be the same physical dimensions as your current set-up and you can use your same manifold.
[Modified by earl, 6:45 PM 1/15/2002]
im pretty sure it will eliminate it.... the comp houing is bigger and it barely clears the block (i test fit one without the a/c bracket with a kooks manifold and it barely cleared... actually kinda touched the block as well)
now if photopoint was working i could show u pictures... motherers shut down though!
94 TuRbO dC2
Mar 7, 2009 08:28 PM
mrbsponge
Jul 20, 2004 05:16 PM
CheezeFrog
Jul 17, 2003 09:19 AM
