EH2 and DC2 Hubs both 32mm?
Hey,
This just popped into my head. Are the civic and teg front hubs both 32mm? I'm asking because I'll be doing a teg front brake swap and was hoping I could reuse the axels.
Someone confirm
Someone confirm
As far as I know the only non interchangable hub is the JDM 98+ ITR ones. For some reason honda switched to a larger prelude size splines.
Great, thanks. Can't believe I never asked this in the two months of researching and collecting parts. I just assumed they were.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">As far as I know the only non interchangable hub is the JDM 98+ ITR ones. For some reason honda switched to a larger prelude size splines.</TD></TR></TABLE>
And those are 36mm right?
Here's another question: When you get a JDM ITR swap with 36mm axels, but you have 32mm hubs, how do you solve that problem? Custom axels?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">
Here's another question: When you get a JDM ITR swap with 36mm axels, but you have 32mm hubs, how do you solve that problem? Custom axels?</TD></TR></TABLE>
You are correct. And to remedy the problem, just run regular teg axles instead of the 36mm ITR's
gqstatus05
Jun 12, 2013 11:10 AM
Jared
Dec 4, 2007 02:14 PM
