Where to find 14mm bolt and nut for rear lower knuckle??
Alright, i went to put my new kyb shocks on, and as im taking the bolt that goes to the rear knuckle, i somehow break the welds on the rear tap nut, i'm going to saw the nut off, can i go to napa autoparts or just get it from the dealer? all i know is that it needs to be a certain grade, all and any help would be great. thanks in advance!
Just get a grade 8 14mm nut and bolt of the appropriate length.
Honda will give you the same thing I'm sure, but at X times the cost.
honda prices are not that bad all things considered but you should make sure you get a grade 8 bolt you can usually tell because there will be 8 raised lines on the head of the bolt
civiceg94
Suspension & Brakes
Aug 4, 2007 02:09 AM
Setsuna F Seiei
May 25, 2006 09:47 PM
MeanGreenEG9
Oct 27, 2002 10:42 AM
