Thread pitch on rear lca bolt
Old 05-24-2006, 09:28 AM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default Thread pitch on rear lca bolt
I need the thread pitch and size for the 14mm rear lower shock bolt which is the exact same bolt that goes through the hub-rear lca. is it m10 x 1.25? im having a hard *** time finding a grade 8 m10 x 1.25 serrated flange nut locally
Old 05-24-2006, 09:30 AM
BlueIntegraBoy's Avatar
Default Re: Thread pitch on rear lca bolt (BrokeAssPinoy)
Yes, it's 10x1.25. I never found one at my hardware stores either.
Old 05-24-2006, 09:38 AM
Default Re: Thread pitch on rear lca bolt (BlueIntegraBoy)
i found one at ace but its only a grade 5. i need a grade 8 or an equivalent class 10 because i grinded off the welded nut on the back of the hub where the rear lca bolt goes through
Old 05-24-2006, 09:52 AM
EG6_GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">I need the thread pitch and size for the 14mm rear lower shock bolt which is the exact same bolt that goes through the hub-rear lca.</TD></TR></TABLE>
It is actually a longer bolt that is flat where the threads begin. If your try to use a inner or outter lca bolt it will strip the welded shock nut when you torque it because it's too short.
They are relatively expensive at Honda, but they are the best design for their intended use. They are worth it IMO.
Old 05-24-2006, 09:58 AM
Default Re: Thread pitch on rear lca bolt (EG6_GUY)
yeah i know that... i need the nut itself. i have the oem bolt I need the right pitch nut thats welded on the back of the hub, i grinded mine off
Old 05-24-2006, 10:02 AM
EG6_GUY's Avatar
My apologies for the useless post.
Old 05-24-2006, 10:28 AM
no problem. ive checked with all of the local fastener suppliers around here and turned out the thread is fine pitched for an m10 and is hard to find
Old 05-25-2006, 09:47 PM
Built B16A's Avatar
Location: hittin corners so hard you can taste my rims..
the only way your going to get that nut behind the body.. is the fastener i showed you..
90IntegraGS1.8L
18
04-18-2007 11:17 AM
OneDirection
Suspension & Brakes
13
01-17-2005 07:19 AM
B18G
01-06-2004 08:48 PM
logictron2000
15
04-24-2003 08:59 AM
Matt B
04-20-2003 07:12 PM
Quick Reply: Thread pitch on rear lca bolt
