Accord Euro R powered EK civic
Old Feb 2, 2005 | 06:42 PM
303TopSecret's Avatar
Default Accord Euro R powered EK civic
I'm having problems with my EK with H22A-R swap. I'm running 98 Accord Type R engine in my EK with and adapter (jumpers), so I could use the obd1 p13 ecu. I think I have everything hooked up right but when I use the obd1 p13 ecu, the car doesn't have Vtec and does not idle right. Someone told me that this could be because of the injectors, and I should try running obd1 injectors...is this true. Right now I'm running AEM EMS stand alone and the vehicle runs ok (191whp 166 ft/lb), but eats alot of gas. I would like to see if I could run obd1 p13 but cannot get it to run right...and info would help. Recommendations apprieciated. Thanks
Old Feb 2, 2005 | 06:47 PM
shocker's Avatar
Do you have all the vtec wires and knock sensor and misc other stuff wired correctly,make sure to check all wiring and check any gasket/seal that could cause oil pressure to drop,vtec will not work without proper oil pressure.Kinda hard to tell what it is without physically doing diagnostics
Old Feb 2, 2005 | 08:46 PM
SuperSlow's Avatar
Default Re: Accord Euro R powered EK civic (303TopSecret)
Without standalone, you will need to wire a resistor box to run obd1 injector even with conversion harness.
Osmin Paz
Oct 25, 2015 08:43 PM
kaoticstyles
10
Jul 12, 2008 06:51 PM
kaoticstyles
Jun 20, 2008 03:30 PM
Wicked Dance
Feb 24, 2005 09:38 PM
