help with wiring where the harness clips have been cut off
Old Feb 2, 2005 | 05:49 PM
importboi22's Avatar
Default help with wiring where the harness clips have been cut off
ok i matched all the colors up except these ones that are left.
-----Passanger Side-----
ENGINE HARNESS SIDE
solid White
Yellow/Green
solid Yellow
white/yellow
yellow/white
side coming from the ECU/Dash harness
Yellow/White one brown dot
Yellow/Green one gray dot
soild Yellow one gray dot
Yellow/White one gray dot
-----Driver side-----
ENGINE HARNESS SIDE
solid blue
solid yellow
black yellow
DASH / ECU HARNEES SIDE
solid white one gray dot
yellow/blk one gray dot
yellow gray dot x 2
the car is a 1990 HF if that would help or if someone with the same car can go look at theres!!! PLEASE HELP ASAP
Old Feb 3, 2005 | 01:44 PM
Default Re: help with wiring where the harness clips have been cut off (importboi22)
bump it
Old Feb 3, 2005 | 02:55 PM
more help?
Old Feb 3, 2005 | 02:59 PM
4drEF's Avatar
Keyboard Humorist
is this under the hood or in the car?
Old Feb 3, 2005 | 03:42 PM
Default Re: help with wiring where the harness clips have been cut off (4drEF)
under the hood
Old Feb 3, 2005 | 04:50 PM
CrazyKoreanCrx's Avatar
Heres the wiring:
Chassis wiring
Old Feb 3, 2005 | 04:54 PM
Default Re: help with wiring where the harness clips have been cut off (CrazyKoreanCrx)
The Other wiring:
Engine wiring
Sorry if anyone complains I'll put it in a link.
__________________________
Aim-crazykoreancrx
https://honda-tech.com/zerothread?id=1118175
Old Feb 3, 2005 | 04:57 PM
4drEF's Avatar
Keyboard Humorist
Ohhhh--- so you have an engine harness and you have the wires coming out from the firewall, but all the plugs are hacked off?
Are you SURE that the engine harness is from the same year and trim chassis?
I ask because the wires should match up color to color.
You will have problems if you try putting Si engine harness to other trim chassis wiring.
At worst case, you can get an Ohm meter and trace all the engine harness wires to the sensors they go to. Then do the same for the chassis wires to the ECU plugs.
This will settle out all that wiring.
Get a hold of a Helm menual or a service manual and trace out the rest - headlights blinkers... all that crud. For the most part those should be all color corrodinated to the service manual.
Old Feb 3, 2005 | 05:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Ohhhh--- so you have an engine harness and you have the wires coming out from the firewall, but all the plugs are hacked off?
Get a hold of a Helm menual or a service manual and trace out the rest - headlights blinkers... all that crud. For the most part those should be all color corrodinated to the service manual.</TD></TR></TABLE>
Yeah Would get a get one anyway. I got those from my Chilton Honda:civic/crx/del sol 1984-95.
Aim-crazykoreancrx
Old Feb 5, 2005 | 11:15 AM
ya i got a helms manual.... the car is a 90 HF and the harness is supposed to be the same.... looks like i got screwed!
exr_pd
Audio / Security / Video
Sep 27, 2011 06:37 PM
311hp
May 19, 2009 09:22 PM
topherchris
Nov 23, 2008 10:55 AM
iHOPEyouCHOKE
May 22, 2006 01:31 PM
