B16 wont idle less then 1,500
Old Feb 2, 2005 | 05:47 PM
Kaneo's Avatar
Default B16 wont idle less then 1,500
When its cold out it will idle at 2,000 for about 1 minutes then drop to 1,500 and wont go any lower. Any help would be great. Thanks
Old Feb 2, 2005 | 05:54 PM
8krdline's Avatar
Default Re: B16 wont idle less then 1,500 (Kaneo)
i have the same problem and i know its my tps bc thats what its throwing a code for. I just havent had time to fix it yet. There are other possibilities though
Old Feb 2, 2005 | 06:17 PM
red91sit's Avatar
Default Re: B16 wont idle less then 1,500 (8krdline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem and i know its my tps bc thats what its throwing a code for. I just havent had time to fix it yet. There are other possibilities though</TD></TR></TABLE>
Like the little screw that stops the throttle body from closing too far, you could try adjusting that if it's not the TPS
Old Feb 2, 2005 | 06:23 PM
ian.'s Avatar
Default Re: B16 wont idle less then 1,500 (red91sit)
you checked for a vacuum leak right?any codes?
k2day
Nov 19, 2011 09:38 PM
N2O INTEGRA
Sep 14, 2007 12:03 PM
Problemo
Jan 29, 2006 04:16 PM
crexer
Jan 15, 2005 09:46 PM
Glocked1
12
Jan 22, 2004 08:13 PM
