need help i'm having a problem with possible crossfire
Old Feb 2, 2005 | 05:24 PM
sharky8513's Avatar
Default need help i'm having a problem with possible crossfire
i don't know what's wrong with the car it could be crossfire from a spark plug or vtec solenoid or distro..i have a 94 civic with a d16z6 motor and it does this stalling when vtec should engage and at about 11-1600 rpm i had a previous post but not much help i'd appreciate it if you guys could help out some here's the link https://honda-tech.com/zerothread?id=1131705
any help is appreciated i hope i can get to the bottom of this in this week or next at the latest i have to smog and pay for tags by the 20th so any help and ideas at all will be appreciated
Old Feb 2, 2005 | 07:53 PM
sharky8513's Avatar
Default Re: need help i'm having a problem with possible crossfire (sharky8513)
bump i need some help. anyone????
Old Feb 3, 2005 | 05:51 PM
sharky8513's Avatar
anybody out there have any idea?
Old Feb 3, 2005 | 07:10 PM
rtype11's Avatar
bad dizzy cap or rotor phasing improperly, ionization of the air in the dizzy cap can cause crossfiring.
Old Feb 3, 2005 | 08:54 PM
sharky8513's Avatar
Default Re: need help i'm having a problem with possible crossfire (rtype11)
does it sound like it could be crossfire by what i wrote in the other post?
Old Feb 4, 2005 | 04:01 PM
rtype11's Avatar
to tell you the truth I really cant tell from your description, I just gave you the cheapest easiest, first thing to consider, if its something else, let us know or more details and locations of noises, symptoms etc.. missing/bad engine gounds????
Old Feb 4, 2005 | 05:15 PM
sharky8513's Avatar
well i just gave my motor another ground wire..and i messed with the dizzy...still no problem solved...however it's giving codes 4,8,9 which are all dizzy so i'm guessing it's bad..i'm still looking i'm thinking it might by the fuel oxygen sensor that's my next purchase...i hate burning this much money
Old Feb 5, 2005 | 08:24 AM
sharky8513's Avatar
anybody else got some input?
Old Feb 5, 2005 | 09:49 AM
v4lu3s's Avatar
RTFM
put a different distributor on there already.
Old Feb 5, 2005 | 10:55 AM
sharky8513's Avatar
Default Re: (v4lu3s)
lol i was messing with the distributor and at one point the codes 4,8,9 went away..so i'm a little confused..and unless someone wants to donate a distro to me..i have to pay 100+ for 1..so i'm trying to go with cheaper things right now..i just replaced my pcv valve..which did help..my idle just smoothed out like nothing else i've done lately...so i gotta give ups for this little thing i went to an auto parts store and it cost me 3.80 with taxes so that was good...who would've though such a miniscule part would make such a difference!
Old Feb 5, 2005 | 11:51 AM
sohc hatch's Avatar
Default Re: (sharky8513)
Try swapping out the enternals of the good dizzy into the one that is giving you problems. That should work if not maybe it can be a bad ignitor ? Try swampping the stuff out though.
Good Day,
RH.
Old Feb 5, 2005 | 01:04 PM
sharky8513's Avatar
Default Re: (egturbohatchback)
so what's the diff between the d15b7 dizzy and the d16z6..just the bolt patter? everything else is the same?
Old Feb 6, 2005 | 12:19 PM
sohc hatch's Avatar
I think the plugs are different. I think one is a 5 wire rectangle plug and the other is a 7 wire circular plug well atleast it is that way for obd0 in references to the SI model and the none SI.
Good Day,
RH.
Old Feb 6, 2005 | 01:03 PM
sharky8513's Avatar
thx..i thought i had my distro in my closet but it's not in there i'm gonna have to go check my storage
Old Feb 7, 2005 | 02:46 PM
sharky8513's Avatar
replaced the distro and no change..i took it to a guy that does smogs hot and spicy and he said my car was running rich...his computer only goes upto 10% but even with an injector dissconnected it was reading 10% so God only knows how high it is i'm only getting an ave. of about 25mpg how much is the average sohc civic using?
Old Feb 7, 2005 | 02:59 PM
sohc hatch's Avatar
Is your O2 sensor good ? You got it hooked up ? Any codes after "working" dizzy installed?
Good Day,
RH.
Old Feb 7, 2005 | 04:47 PM
sharky8513's Avatar
Default Re: need help i'm having a problem with possible crossfire (egturbohatchback)
at this point i have a big headache so i'm trying to stop thinking about it but it's 1 of those thing that i just can't stop...my 02 sensor seemed fine it's plugged in correctly i'm not sure if it could be a fuel injector or more than 1...or what i'm ready to bang my head against the motor to see which 1 goes out first...of course we all know the answer to that..after doing some research on previous posts i'm dumbfound anyway i'm gonna make a new post and link this to the next 1..because this title doesn't seem to get much attention
undaj
Sep 5, 2013 11:41 AM
noble4ws
Sep 3, 2004 07:43 AM
