Anybody have an oil pressure guage?
Old Jan 15, 2002 | 09:12 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Anybody have an oil pressure guage?
I've been thinking that an oil pressure guage might be a useful thing to have. Do any of you have a mechanical oil pressure guage and how hard was the install? Thanks.
Old Jan 15, 2002 | 09:18 AM
Crazydave's Avatar
Default Re: Anybody have an oil pressure guage? (ActiveAero)
Electrical..
didn't want oil in my passenger compartment..
the pain is getting to the where you hook up to the block
it's on top of the oil filter.. and you have to snake you hand and wrench around the exhaust..
1/8 bsp -> -4an braided line -4an tee -> 1/8 NPT -> sender
see this for proper installation
and the other side goes to 1/8 BSP -> Oil pressure switch (or 1/8 npt with 1/8 npt pressure switch)
http://www.theoldone.com/articles/oilpressure/
[Modified by Crazydave, 10:19 AM 1/15/2002]
Old Jan 15, 2002 | 09:21 AM
HX_Guy's Avatar
I have one. Pretty easy to install, I used -3an steel braided line instead of the crappy hose it comes with (Autometer)
Get a fitting for the back of the block, doesnt even have to be a Tee because you cna throw the stock pressure sensor in the trash once you install the gauge.
You cna either use a 1/8" NPT fitting (isnt quite the same thread...but it works) or buy a 1/8" BSPT to NPT fitting. I have this fitting at home and some -3an line if youre intrested in buying it.
Old Jan 15, 2002 | 09:50 AM
Crazydave's Avatar
Default Re: Anybody have an oil pressure guage? (HX_Guy)
Oh yeah..
pegasus racing is out of the the bsp to npt adapters..
but they have bsp to an
so you may wanna talk to HX Guy
I'd still keep the switch.. cause the damn oil light will stay on
[Modified by Crazydave, 10:52 AM 1/15/2002]
Old Jan 15, 2002 | 10:00 AM
HX_Guy's Avatar
Default Re: Anybody have an oil pressure guage? (Crazydave)
No it wont..I dont ahve the stock sensor and no oil light
Old Jan 15, 2002 | 10:29 AM
Crazydave's Avatar
hmm...
mine went off when I disconnected mine...
So hooked it back up
Old Jan 15, 2002 | 11:02 AM
HX_Guy's Avatar
Weird...this guy I know did the same thing I did an didnt get a light either.
Old Jan 26, 2002 | 12:16 PM
FitCRX's Avatar
I don't get a light either...anyone know?
Old Jan 26, 2002 | 01:23 PM
fixhondas's Avatar
Default Re: Anybody have an oil pressure guage? (FitCRX)
the light comes on when there is no oil pressure because it is a normally closed switch- with oil pressure the circuit opens and you have no light. unplug it and it wont come on.
Old Jan 26, 2002 | 06:38 PM
mannyman's Avatar
El Veterano de Sur Califas
ok, i get what u are saying, but what fitting is needed to hook up to the back of the gauge??? has to be a -3an that flares to some female size.
Old Jan 27, 2002 | 02:57 AM
AfEn808's Avatar
New User
Default Re: Anybody have an oil pressure guage? (mannyman)
you can use a mechanical I would recommend a changing the hose every year though electricals good but the install sucks and dont use brass pipe fittings they crack easily I had to learn the hard way twice taking a little piece of pipe out of your block is not fun.
Old Jan 28, 2002 | 09:39 AM
Crazydave's Avatar
Default Re: Anybody have an oil pressure guage? (fixhondas)
Mine musta been grounding somewhere...
I'd still rather have the oil light..
Old Jan 28, 2002 | 09:42 AM
speedymon's Avatar
my oil light didn't go off either. Pulled it off when i installed the gauge and no light.
Old Jan 28, 2002 | 09:46 AM
WuShu's Avatar
New User
Default Re: Anybody have an oil pressure guage? (speedymon)
I had a mechanical oil pressure gauge. Install wasnt bad at all, i just got a bunch of fittings from home depot and ghetto rigged it, about oil leaking into your car, i believe someone else posted this a long time ago but that is just as silly as an electrical gauge setting your dash on fire. If you install it correctly it will not leak.
EFsideways
Jan 1, 2008 01:52 PM
thinknology
Jun 9, 2004 02:54 PM
pelotudo
Aug 18, 2002 06:31 PM
Petah
19
May 6, 2002 05:41 AM
NeXtLeVeL_TyPe_R
Oct 2, 2001 09:50 PM
