Transmission is getting hard to shift, sometimes wont!
Old Feb 2, 2005 | 04:16 PM
dlszrfn's Avatar
Default Transmission is getting hard to shift, sometimes wont!
My transmission has been acting very weird lately. It is very hard to down shift, and yes, i depress the clutch the whole way to the floor!
It started with just not want to shift from 3rd to 2nd but now tonight it wouldnt downshift to any gear. i was trying to go from 5th to 4th but it wouldnt, so i tried 3rd and it wouldnt. so i just taped the brakes and tryed 2nd, it wouldnt, so i went back to 4th and it all finnally wanted to work again.
Whats wrong with it?
i drive a 1990 Honda CRX DX with a DX tranny
Old Feb 2, 2005 | 04:19 PM
91civicEX's Avatar
Default Re: Transmission is getting hard to shift, sometimes wont! (dlszrfn)
change the fluid and report back
Old Feb 3, 2005 | 09:57 AM
90HFCrX's Avatar
try adjusting your clutch cable tighten it down then let us know ok! that should help your problem
Old Feb 3, 2005 | 02:29 PM
crxtreme89h's Avatar
Default Re: (90HFCrX)
Check your shift linkage too. Tighten things up a bit if their loose. Maybe take it off, then re-install it.
Old Feb 3, 2005 | 02:50 PM
krazie1's Avatar
BANNED
Default Re: (crxtreme89h)
having same problem since I change or swapped in Kaaz LSD
first sometimes goes in and others time won't
doesn't matter hot or cold....
WERD!
Old Feb 3, 2005 | 06:05 PM
ijjz's Avatar
I tried the Syncromesh stuff from GM, Pennzoil bottle. Works like a dream, only $15 for 3 bottles.
Old Feb 3, 2005 | 06:29 PM
mikerbike's Avatar
Default Re: Transmission is getting hard to shift, sometimes wont! (ijjz)
Is your pilot bearing good? Mine froze up and kept the input shaft spinning when I depressed the clutch pedal. It's something you might want to check.
Old Feb 16, 2005 | 03:25 PM
dlszrfn's Avatar
double clutching solved the problem, or shifting slowly.
i assume the oil level is low, but i just cant get enough free time to check it.
school sucks!
Old Feb 16, 2005 | 03:31 PM
crexhf17's Avatar
it maybe clutch related and you might be runnin on E w/ tranny fluid
Old Feb 16, 2005 | 03:33 PM
b16bluef's Avatar
Default Re: Transmission is getting hard to shift, sometimes wont! (crexhf17)
the springs in teh clutch are bad i had the problehem and only went in gear while car was off because i kept driving like that so i needed a new clutch
Ef4doorwagon
Nov 28, 2014 10:17 PM
bmoreb18c1
Jul 20, 2013 07:17 PM
avargas28
Aug 2, 2011 04:19 PM
sohc prelude
Feb 26, 2006 07:26 PM
boomslang
Nov 18, 2001 12:00 AM
