Greddy oil catch can installed
Old Feb 2, 2005 | 02:23 PM
crxvtecturbo's Avatar
* B A N N E D *
Default Greddy oil catch can installed
I got all of my questions answered by REXTEC
Modified by crxvtecturbo at 11:14 PM 2/3/2005
Old Feb 2, 2005 | 02:28 PM
jdmcrx34's Avatar
Default Re: Greddy oil catch can installed (crxvtecturbo)
i think it looks very nice, i cant wait till i get a turbo in my crx. by the way your brake fluid looks low.
Simon Tibbett's Avatar
Default Re: Greddy oil catch can installed (jdmcrx34)
I like
Old Feb 2, 2005 | 02:31 PM
rextec's Avatar
if its turbo you mounted the lines wrong. the way you have it will only work when you are not in boost.
Old Feb 2, 2005 | 02:33 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 &raquo;</TD></TR><TR><TD CLASS="quote">i think it looks very nice, i cant wait till i get a turbo in my crx. by the way your brake fluid looks low.
I am not driving the car right now waiting on new turbo i noticed that today i will be adding some before the new turbo goes on
Old Feb 2, 2005 | 02:34 PM
* B A N N E D *
Default Re: (rextec)
Old Feb 2, 2005 | 03:22 PM
rextec's Avatar
Default Re: (crxvtecturbo)
do it like this and baffle the inside of your catch can so it will catch the oil particles.
Old Feb 2, 2005 | 04:41 PM
* B A N N E D *
ttt
Old Feb 2, 2005 | 05:34 PM
speeddave's Avatar
there's a ton of info in the archives on catch cans, so much in fact its confusing...
most people recommend removing the two plugs in back, and running a big line from the valvecover, all these going to a baffled can.
OT... but whats the rest of the setup?
Old Feb 2, 2005 | 06:16 PM
* B A N N E D *
Default Re: (speeddave)
ttt
Old Feb 2, 2005 | 07:10 PM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">
do it like this and baffle the inside of your catch can so it will catch the oil particles. </TD></TR></TABLE>
On a race-only car, I'd say ok, that solution looks fine. On a street driven car plumb the tank to the pcv and intake just like the photo. I run mine on the street and strip and have mine routed just like crxvtecturbo. Tom Payn from Payn Technologies recommended that I plumb it like this for my application, I tend to agree, and it has worked very well. You still have on-boost ventilation through the filter on the cam cover.
* B A N N E D *
bump^
Old Feb 2, 2005 | 07:14 PM
* B A N N E D *
Modified by crxvtecturbo at 11:15 PM 2/3/2005
Old Feb 2, 2005 | 10:35 PM
rextec's Avatar
it will relieve pressure but will not suck out blowby gasses. at full boost you are usually turning high rpm's when blowby is most prominent. the way i posted will work ALL of the time, if you understand how vacume is created you would see my point. the pre turbo pipe will ALWAYS produce vacume. run it however you want man im just tryin to help you out and back up everything i say with facts. i did all of this research already and wanted to save you some time.
Old Feb 2, 2005 | 10:37 PM
W O T's Avatar
how many ****** forums you need to post this in
Old Feb 2, 2005 | 10:38 PM
rextec's Avatar
^^^^^lol
Old Feb 3, 2005 | 03:32 AM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">it will relieve pressure but will not suck out blowby gasses. at full boost you are usually turning high rpm's when blowby is most prominent. the way i posted will work ALL of the time, if you understand how vacume is created you would see my point. the pre turbo pipe will ALWAYS produce vacume. run it however you want man im just tryin to help you out and back up everything i say with facts. i did all of this research already and wanted to save you some time.</TD></TR></TABLE>
If you knew how to spell vacuum, maybe more people would listen. I fully understand how the engine creates vacuum, however the setup you have drawn will not properly be able to create a vacuum inside the catch can because vacuum at the air intake is not even in the same ballpark as it is in the intake. I'm not saying your setup is wrong, it's just not efficient for a street car.
Old Feb 3, 2005 | 09:05 PM
rextec's Avatar
im trying to help this guy out for ***** sake. i dont need an english lesson. this **** makes h-t a shitty place. when some one tries to help, and someone like you disects each and every thing you type. you knew what i meant by vacume. as for it not being efficent....i think you are wrong. the canister will always be under vacuum and always be scavenging the crankcase. and how was your post helpfull??? you didnt even give him an alternative setup. you are useless...... to trolls like yourself.
Old Feb 3, 2005 | 09:15 PM
ridexstraight's Avatar
word
Old Feb 3, 2005 | 09:23 PM
* B A N N E D *
Old Feb 4, 2005 | 03:02 AM
Finland's Avatar
I don't think it's necessary to start calling people names..that kind of thing makes HT a shitty place. The person that started the thread asked a simple question, I provided a simple answer, you start accusing me of not understanding vacuum, I accuse you of not even knowing how to spell vacuum, you call me a 'troll'....
Bottom line, there are multiple ways to route a catch can, each way has their proper application, advantages and disadvantages..
I'm spent.
Modified by Boondock Saint at 4:52 AM 2/4/2005
mugenNR10
Mar 23, 2006 12:37 AM
crxvtecturbo
Feb 3, 2005 01:41 PM
crxvtecturbo
Feb 2, 2005 07:28 PM
turbopanda
Mar 3, 2004 07:41 PM
ozzyman
80
Jan 13, 2004 09:16 AM
