need wiring for DC (ITR) instrument cluster into EG (Civic) - migs?
anyone did this swap a DC cluster into a EG chassis, need the wiring comparisment in specific, and other pointers
its a JDM ITR cluster into a 92 Civic....
i know Migs had one for the EK, which was helpful but need it for a DC...
tia
tia
got my GSR cluster installed today.. same wiring as an ITR only different redline i believe.. here is some pics of it.. and also a good wiring schematic i found on honda-tech.com from when someone installed a teg dash in a 5gen civic.. it helped me out a lot.. also i give thanks to migs also for the help..
teg's blue left side plug (13 pins)
1.blu-tach signal
2.grn/org-check engine indicator
3.yel/red-oil pressure switch
4.-
5.wht/blu-charge indicator
6.-
7.yel/grn-coolant temp
8.blk-ground
9.red/blu-cruise (if you have cruise)
10.yel-hot
11.-
12.pink-maintenance (not used)
13.-
teg's right side blue plug (16 pins)
1.grn/red-e.brake signal
2.red/grn-high beam
3.grn/yel-right turn
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
9.blu/red-abs (not used)
10.grn-trunk switch
11.org-vehicle speed sensor
12.-
13.blu/wht-low fuel (not used)
14.yel/wht-fuel gauge
15.lt grn/red-door switch (not used)
16.red/blu-seat belt
civic's left side grey plug (12 pins)
1.yel/wht-fuel gauge
2.yel/blu-vehicle speed sensor
4.grn/blu-left turn
5.wht/blu-charge
6.yel/red-oil pressure switch
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
civic's right side grey plug (10 pins)
1.red/grn-high beam indicator
2.grn/red-e brake signal
3.-
4.-
5.grn/org-check engine indicator
6.blk-ground
8.yel-hot
9.grn-trunk switch
10.blu/wht-seat belt
1.blu-tach signal
4.-
6.-
8.blk-ground
10.yel-hot
11.-
13.-
2.red/grn-high beam
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
10.grn-trunk switch
12.-
4.grn/blu-left turn
5.wht/blu-charge
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
3.-
4.-
6.blk-ground
8.yel-hot
9.grn-trunk switch
Is the install flush with the rest of the dash? When I saw the picture of the S2000 dash in the eg it looked like it was poping out a lot. Also how long did this take you 92CivicEX?
it does not sit in there completly flush.. i had to dremal some of the stock guage cluster surrounding away to make it fit in better.. i want to get a dash trim and try it agian to make it a little better but i am happy w/ it for now.. its looks good and everyone is amazed when they get into my car and see that cluster is not the same as every other civic.. if you want i can send closer pics so you can see how it looks.. let me know..
i know that i have seen it for the civic guage cluster but for the integra, i dont think i have ever seen one..
btw, Maximus here is a link to what inspired me to install the integra cluster into my civic.. i have no idea how they got it looking soo good, its almost like the put the integra guages into the civic housing and that is why its lined up perfect and looks flush..
my fault everyone... here is the link from the the above post..
http://community-2.webtv.net/Lucas56...idclusterpics/
yes i will get some better pics of the of my gauge cluster and either email them to you or send a link..
btw, anyone figure out the srs light yet??? thanks
do you need the connectors from the integra? cuz i know the stock civic connectors are different. how did you guys do yours? did you splice and how do you move the pins around?
This is something I've been wanting to do for a while, but I haven't come across much information about it. Are the 94-00 GS-R clusters the same? If not, what years are the ones I need to look for? I can get a great deal on a 98 cluster to put in my 92 VX. So along with the cluster I would need the Integra plug connectors as well? With the wiring would I just take all of the wires out of my factory plugs and re-pin them into the Integra plugs?
Is it hard to get it to position and fit correctly into the dash opening. I saw that you said that you used a Dremel to grind away some of your trim. Do you think it is possible to get it in there without doing that? I don't want to do anything that can't be reversed. My old trim panel cracked and I had a hard time finding the one I have now, so I would rather not cut it if possible.
its to late for me to answer questions now.. im gonna get some sleep now and then friday morning clean my car and also get some better pics and info for everyone.. its not difficult to do at all..
How do you put these gauge clusters in the car correctly? I would like to switch my 94eg civic dx cluster to like a Teg or something. Where can I get them and who will install them?
Dwight Schrute
Jan 24, 2008 04:54 PM
I-VTECRX
Mar 3, 2003 09:03 PM
