Anyone with a 5 lug swap?...Axle question...
I'm just wondering what your running for axles?
What 36mm outer CV?
Id like to run just the stock SI axles if possible.
Thanks,
Bryson
What 36mm outer CV?
Thanks,
Bryson
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noah ***** »</TD></TR><TR><TD CLASS="quote">check out the FAQ thread at the top of the crx/ef page. its got all the info</TD></TR></TABLE>
Theres no link in there that has anything to do with the 5 lug suspension...
ask member "black r" he has a 5 lug on a hatch. he also has the whole type r inside the hatch. ask him hell help you out. his link was in there, dont know what happend
plus i already serached a while back
https://honda-tech.com/zerothread?id=1094264
links and links
http://battlecat.8m.com/ITR%20...A.htm
links and links
From: hittin corners so hard you can taste my rims..
JDM CTR, and USDM ITR, are normal 32 count splines... ONLY the JDM ITR had 36 count splines.
so any USDM 5 lug, or JDM CTR's are direct replacement.
if you want JDM ITR 5 lug, you'll need CRV/prelude/JDM ITR outer axle joints.
B00STidDc5
Jul 7, 2005 10:53 AM
