Valve adjustment question.
Old Jan 15, 2002 | 07:16 AM
speedymon's Avatar
Default Valve adjustment question.
can i just use a 10mm socket instead of the adjustment tool from snap on?
Spade's Avatar
Default Re: Valve adjustment question. (speedymon)
On what engine?
Old Jan 15, 2002 | 07:17 AM
speedymon's Avatar
Default Re: Valve adjustment question. (Spade)
sorry B18c1
Old Jan 15, 2002 | 07:20 AM
Spade's Avatar
http://www.c-speedracing.com
They have modified a wrench to do the job.......how to section.
Old Jan 15, 2002 | 07:21 AM
speedymon's Avatar
yeah i really didn't want to bend tools. The socket can't work?
[Modified by speedymon, 11:35 AM 1/15/2002]
Old Jan 15, 2002 | 07:45 AM
Spade's Avatar
The socket won't work because you need to hold the screw (which is in the middle of the nut) still while tightening down the nut
It is easiest to get the Snap on tool......it will pay for itself after two adjustments!!
Old Jan 15, 2002 | 09:05 AM
b18bottlehatch's Avatar
New User
you can use a regular open ended wrench and a regular flathead screwdriver and save yourself $60. that tool doesn't make it THAT MUCH easier, cause you can still turn the screwdriver a little bit while you're tightening the locknut.
Old Jan 15, 2002 | 01:09 PM
owen_the_soyboy's Avatar
Default Re: Valve adjustment question. (b18bottlehatch)
Hey, I did it so can you.
You CAN use a 10mm DEEP SOCKET, holding it with VICEGRIPS,
placing your flathead screwdriver thru the center of the socket to adjust the valves on a GSR or ITR motor.
On a LS motor just use a 12mm DEEP SOCKET.
The socket is tough to hold tight sometimes, because the work area will be oily and th evice grips are not able to grip 90 degrees to the deep socket... so it helps if you flatten out two sides (opposing sides) of the socket to help the torque you can hold. Hope That Helps..aka HTH
jordy478
Aug 7, 2012 08:47 PM
redDAinteg
Oct 24, 2005 02:22 PM
Soled Out
Aug 17, 2003 09:32 AM
BrandonClaps
Apr 14, 2003 07:23 AM
Jamison
Mar 16, 2002 02:17 PM
