BulkHead / Core Support Removal
I've got my crx stripped down to the core support and need to remove it an replace it with a new one. I know the welds have to be drilled out, I don't know how to locate all the welds. Is there a chart or guide available somewhere that shows the points the Support is welded on to the car? How many welds are on there? Any help would be appreciated. Pictures would also be good.
Thanks alot
TK
Thanks alot
TK
Just clean the old part and you will be able to see them as slight indentations of the surface. Just remember that sometimes, one can be close enough to another so as to overlap. Also, there are a couple hidden inside the some holes near the bottom of the support.
