Trans grind
Old Feb 2, 2005 | 08:37 AM
dblock91's Avatar
Default Trans grind
i think my throw out/ release bearing is shot because downshifts=grinds, mainly in 1st gear. i have heard that this is a common problem amongst older civics...anyone have any input on my situatuion
Old Feb 2, 2005 | 08:40 AM
The ZC's Avatar
Default Re: Trans grind (dblock91)
You are not supposed to downshift into 1st! It dosn't have a sycro and thing over a certian speed it will grind!
Old Feb 2, 2005 | 08:41 AM
PHOBIA's Avatar
yeah man only put it in first under 5mph.
Old Feb 2, 2005 | 08:50 AM
EF9 JAMS!!!'s Avatar
ya man i know what you mean. my first grinds pretty bad and it sounds like it's starting to do it in second but i mean it drives perfect other than that.
Old Feb 2, 2005 | 08:52 AM
dblock91's Avatar
Default Re: Trans grind (hatch91JDM)
i dont downshift into 1st goin 75 mph
i mean at slow speed
Old Feb 2, 2005 | 09:10 AM
EP3_05's Avatar
Just don't downshift into first until you stop then. Simple fix and no need to tear the car apart. I see no reason to downshift into first unless you are going under 5mph.
Old Feb 2, 2005 | 09:19 AM
manson's Avatar
Default Re: Trans grind (91civic)
even at 5mph you don't need to downshift.... work the clutch and your straight...
the only time you should downshift to first is at a complete stop.
Old Feb 2, 2005 | 07:15 PM
dblock91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dblock91 &raquo;</TD></TR><TR><TD CLASS="quote"> downshifts=grinds, mainly in 1st gear.</TD></TR></TABLE>
what i should have said was, downshifting from 3,2 grinds, also at a complete stop from neutral to 1st sometimes grinds, when the car is idleing there is a rattle noise comming from the transmission side, when the clutch is engaged rattleing stops
Blackline47
Honda Civic (2006 - 2015)
Dec 7, 2006 02:58 PM
xxmastermindxx
Nov 23, 2006 01:55 PM
z51LS2
Apr 16, 2006 05:17 PM
01PYTypeR#1140
Jun 5, 2004 07:38 PM
jeanlo
12
Oct 8, 2003 07:00 AM
