detonating through the intake
Old Feb 1, 2005 | 07:54 PM
Kutsuju_TurboCivic's Avatar
Default detonating through the intake
Does anybody know what would cause intake detonation. This is racking my brain. I have tried everything. Retarding the cam, adding fuel, taking away fuel. the car is a 2002 civic so I cant adjust the ing. timing. I know it is detonating through the intake cause it keeps pushing out my IAT sensor. It is fine at half throttle but as soon as I go to full throttle and the boost starts to get to 3psi POP. Please help.
Old Feb 2, 2005 | 05:38 AM
Default Re: detonating through the intake (Kutsuju_TurboCivic)
bump
Old Feb 2, 2005 | 06:40 AM
mmuller's Avatar
Mad Scientist
what engine management are you using?
Old Feb 2, 2005 | 06:49 AM
devnull's Avatar
Change your spark plugs. It sounds like your plugs might be to hot and they are pre-igniting. Either go colder or iridium.
Old Feb 2, 2005 | 09:17 AM
tgreaves's Avatar
Default Re: (qi_doy)
Ever try changing the iat sensor so that it doesnt come out.. Thats probably not detonation, its probably just boost pushing the sensor out of the rubber grommet..
Old Feb 2, 2005 | 05:53 PM
Default Re: (tgreaves)
I am using denso irid. IK22's. I have 2 extra injectors on a stand alone computer. I know is is detonating back in to the intake manifold cause you hear a loud pop in the charge pipe and the IAT sensor pops out. It only comes out when it detonates. It never pops out other than that even at 13psi.
Old Feb 3, 2005 | 05:44 AM
tgreaves's Avatar
Default Re: (Kutsuju_TurboCivic)
Not sure how you could get detonation back through the intake pipe.. I would guess that maybe your ignition timing is wayyyyy off or you have a really bent valve(s).. Maybe also your cam timing is way off..
Old Feb 3, 2005 | 09:26 AM
1fastVX's Avatar
Where are your extra 2 injectors placed? Any chance that the gas from them is pre-igniting in the hot manifold causing the IAT to pop out?
John
Old Feb 8, 2005 | 05:02 PM
Default Re: (1fastVX)
they are right inder the throttle above the intake manifold. that could be posible
Old Feb 8, 2005 | 09:23 PM
HoOridin's Avatar
maybe a lean misfire?... i seen those alot...
Old Feb 9, 2005 | 05:46 AM
tgreaves's Avatar
Default Re: (HoOridin)
Right but a lean misfire wouldnt come back through the intake, it would go out the exhaust unless there are bent valves or cam timing is way off..
cloudconnected85
Nov 10, 2008 06:08 PM
smcowman
Apr 9, 2007 09:05 PM
projectpat817
Jan 10, 2005 12:34 PM
BlendedEJ8
Oct 3, 2003 08:33 AM
