GSR Intake Manifold ..... What is this for ?
Old Feb 1, 2005 | 07:52 PM
Vera's Avatar
Default GSR Intake Manifold ..... What is this for ?
i was wondering if someone could tell me what this is hole is for ?
mine is plugged
Old Feb 1, 2005 | 08:24 PM
jdm_cars's Avatar
Default Re: GSR Intake Manifold ..... What is this for ? (Vera)
I believe that is for the EVAP Purge solenoid. IMHO you can do without this, unless you live in Cali which does SMOG check.
Old Feb 1, 2005 | 08:30 PM
Vera's Avatar
Default Re: GSR Intake Manifold ..... What is this for ? (jdm_cars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_cars &raquo;</TD></TR><TR><TD CLASS="quote">I believe that is for the EVAP Purge solenoid. IMHO you can do without this, unless you live in Cali which does SMOG check.</TD></TR></TABLE>
i thought the evap went to the canister .. and then to the hole on the side of the manifold
Old Feb 1, 2005 | 08:39 PM
IN VTEC's Avatar
PCV vacuum source. Unless your PCV is routed some other way to a vacuum source, you'd better hook it back up.
Old Feb 1, 2005 | 08:43 PM
Vera's Avatar
Default Re: GSR Intake Manifold ..... What is this for ? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">PCV vacuum source. Unless your PCV is routed some other way to a vacuum source, you'd better hook it back up.</TD></TR></TABLE>
i believe mine is routed from that outlet in the pic at the bottom right .. that has some white on it or something ...thats where it looks to be i believe
Old Feb 1, 2005 | 08:47 PM
IN VTEC's Avatar
Oh...so you're dumping all your coolant into the crankcase then. That's good.
Old Feb 1, 2005 | 09:10 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Oh...so you're dumping all your coolant into the crankcase then. That's good.</TD></TR></TABLE>
haha ah **** .. maybe its not .. i will look again ..
Old Feb 1, 2005 | 11:42 PM
SHystrdyGSRtdy's Avatar
LOL
Fat Chick Magnet
Oct 9, 2006 10:19 AM
Ransom
May 14, 2006 11:24 PM
dat_flip
Nov 2, 2004 12:32 PM
DC 2
Mar 12, 2004 05:10 AM
Garrett
Jul 20, 2003 11:44 AM
