question about JL
Old Feb 1, 2005 | 04:30 PM
k7q's Avatar
k7q
Default question about JL
which is better? 10" JL W6 or 12" W3.....i have both and when i took out my W3 and added in the W6...its sounds weaker.....is it because of the amp???
Old Feb 1, 2005 | 04:45 PM
GSteg's Avatar
what size box? the 12w3 is going to get louder than the 10w6. simply due to the displacememnt the 12w3 has over the w6.
Old Feb 1, 2005 | 04:51 PM
k7q's Avatar
k7q
Default Re: (GSteg)
each sub has the same size box... damn if i knew this earlier i would have save me some money
Old Feb 1, 2005 | 06:25 PM
GSteg's Avatar
how many cubic feet are each sub seeing? are you going to sell your 10w6?
Old Feb 1, 2005 | 06:26 PM
k7q's Avatar
k7q
Default Re: (GSteg)
yea imma try to sell it...
Old Feb 1, 2005 | 07:14 PM
GSteg's Avatar
how much do u want it for?
Old Feb 1, 2005 | 07:24 PM
upsfutch's Avatar
Default Re: question about JL (k7q)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k7q &raquo;</TD></TR><TR><TD CLASS="quote">which is better? 10" JL W6 or 12" W3.....i have both and when i took out my W3 and added in the W6...its sounds weaker.....is it because of the amp???</TD></TR></TABLE>
what kind of amp are you using and the w6 is more powerfull speaker. and your box could be screwed
Old Feb 1, 2005 | 07:39 PM
rawkus's Avatar
Default Re: question about JL (upsfutch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by upsfutch &raquo;</TD></TR><TR><TD CLASS="quote">
what kind of amp are you using and the w6 is more powerfull speaker. and your box could be screwed</TD></TR></TABLE>
One speaker can't be more 'powerful' then another.
The W6 is more oriented towards sound quality. W3 is considered slightly lower end, but still quite good. Given the same amount of throw, a 12 will always be louder then a 10, due to being able to move more air. Personally, I would stick with the W6 and optimize the box, but it's your call.
Dan
Old Feb 1, 2005 | 08:57 PM
k7q's Avatar
k7q
Default Re: question about JL (rawkus)
thanks for the info..
Old Feb 2, 2005 | 08:11 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k7q &raquo;</TD></TR><TR><TD CLASS="quote">which is better? 10" JL W6 or 12" W3.....i have both and when i took out my W3 and added in the W6...its sounds weaker.....is it because of the amp???</TD></TR></TABLE> The 12w3v2 uses a 1 to 1.5 cu.ft sealed box and a 2 to 3 cu.ft ported box and is rated at 300 watts RMS, the 10w6v2 uses a .5 to 1 cu.ft sealed box and a .75 to 1.25 cu.ft ported box and is rated at 400 watts rms.
It is very important that the sub is in the proper sized box, and that it has the right amount of power going to it. also depending on what imp. the VCs are, 2,4 or 6 ohms the efficincy is diff. on the 12w6v2 it is 86.7dB for 2ohm, 86.9dB for 4ohms, and 86.9db for 6ohms on the 10w6vD4 only available in a 4ohm its efficincy is only 83.7dB and thats a 3dB diff. all ratings are at 1W/1m 94
Old Feb 2, 2005 | 03:25 PM
upsfutch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawkus &raquo;</TD></TR><TR><TD CLASS="quote">
Dan</TD></TR></TABLE>
Actualy the w6 is more power hungry if you have one then you now what im talking about. Some subs just want way more power. and if you dont give it to them they dont sound good. I have had a jl 15w3 and now a 15w6 and there is a difference the amp that I used didnt work well with the w6 it was a keenwood. I had to get more juice so I went to an autoteck mx1300 and now its right. If he has a bobo amp and he is trying to run a more powerfull sub then what he was running then it wont sound good.
Old Feb 2, 2005 | 03:59 PM
rawkus's Avatar
Actualy the w6 is more power hungry if you have one then you now what im talking about. Some subs just want way more power. and if you dont give it to them they dont sound good. I have had a jl 15w3 and now a 15w6 and there is a difference the amp that I used didnt work well with the w6 it was a keenwood. I had to get more juice so I went to an autoteck mx1300 and now its right. If he has a bobo amp and he is trying to run a more powerfull sub then what he was running then it wont sound good. </TD></TR></TABLE>
Some subs are more efficent then others, this is true. But making sound is about moving air. A larger cone moves more air then a smaller one and the farther a cone moves, it will move more air. So... given the same amount of cone movement, a larger speaker will always be louder then a smaller one. Thats all I am trying to say.
Dan
Old Feb 2, 2005 | 06:33 PM
upsfutch's Avatar
[QUOTE=rawkus]
you can have a 10w7 and it will be loud but the 15w3 will just drop lower, may not be as clean but will pund
Audio / Security / Video
10
Aug 29, 2006 05:38 PM
thelonerangers
27
Mar 27, 2006 12:44 PM
onemanlan
Apr 6, 2005 11:00 PM
redrex
Jun 22, 2004 05:03 PM
DSMTurboAWD
22
Aug 10, 2003 09:57 AM
