weight diffrence of EF drums to Rear Discs??
Old Feb 1, 2005 | 03:12 PM
crxb20ed's Avatar
Default weight diffrence of EF drums to Rear Discs??
just picked up gsr brakes all around formy 90 crx dx.. I was atleast thinking about putting the rears on till I get the right knuckles for the front... but I was wondering how much heavier are the disc than the drums?? thanks!
Old Feb 1, 2005 | 05:07 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: weight diffrence of EF drums to Rear Discs?? (crxb20ed)
Since you've got them, you should weight them (when you do the swap) & let us know...
Old Feb 1, 2005 | 05:12 PM
cursED's Avatar
IIRC, 8lbs. per side is the weight that is floating around. It has been asked before. Do let us know if you are able to weigh both.
Old Feb 1, 2005 | 05:20 PM
DocSean's Avatar
Default Re: weight diffrence of EF drums to Rear Discs?? (cursED)
8lbs difference per side?
Old Feb 1, 2005 | 05:33 PM
EL Vap133's Avatar
What year GSR brakes did you get?
Old Feb 1, 2005 | 05:53 PM
deftones0817's Avatar
Default Re: weight diffrence of EF drums to Rear Discs?? (EL Vap133)
i love drums and would never trade them for disc. HF owns all. But then again i would switch from disc to drum either. I say rock what is on it stock and just upgrade front brakes where it matters....
Old Feb 1, 2005 | 08:47 PM
cursED's Avatar
Default Re: weight diffrence of EF drums to Rear Discs?? (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">8lbs difference per side?</TD></TR></TABLE>
I don't think I've ever come accross a hard number from a source I knew personally to be totally reliable. I'm still running drums.
Try searching & see what you come up with. Here's one of the more recent threads I remember reading that touched on this subject - I assure you there are more:
https://honda-tech.com/zerothread?id=914493
_
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Since you've got them, you should weight them (when you do the swap) & let us know...</TD></TR></TABLE>
Word up.
Old Feb 2, 2005 | 02:40 AM
crxb20ed's Avatar
yeah I think Ill do that , they are off a 00' gsr, I guess Ill just remove one side and weigh it, like you guys said, might as well switch to discs since I have it,, its just I want my brakes a little more reassuring when I am almost 110 mph at the end of the 1/4... little scary
Old Feb 2, 2005 | 07:30 PM
cursED's Avatar
Try a different pad. Better than adding weight. Most of your braking is done at the front anyway. Talk to Andy at http://www.cobaltfriction.com.
Old Feb 2, 2005 | 08:07 PM
BOSS-REX's Avatar
The weight differences is not enough to worry about.
I put disc brakes on the back of my 88 crx si and it stops better than before and my car didn't get slower from the extra weight, I used 90-93 teg disc, It also stops much better in the rain when the brakes get wet, looks more cool, they last longer than drum, easy er to change the pads, they don't fade down big hills, so put them on, and enjoy slamming on your brakes and stopping on a dime.
Old Feb 4, 2005 | 07:33 PM
crxb20ed's Avatar
Default Re: weight diffrence of EF drums to Rear Discs?? (BOSS-REX)
sounds good Ill be doing this this weekend,.. I got 00' gsr rears,, what ebrake cable can I use? and did you have a problem w/ you stock brake hoses? thanks!
Old Feb 4, 2005 | 10:01 PM
BOSS-REX's Avatar
I used the brake lines from a 91 CRX SI 4 wheel disc brake car,the part number is [46430-SK7-931] special order took a couple days, I got them from the Honda dealer in Costa mesa Ca. I used the e-brake cable from the 90-93 teg its a little longer but it works fine just get two cable clamps and rout them so the cables so they wont bind. Its a little tricky getting the e-brake cables through the chassis but have Patience it will all go in and work great it took me about 4 hours to do the whole job from ground to jack to ground.
Old Feb 4, 2005 | 10:14 PM
88civichbz6's Avatar
i'm getting ready to do the rear disc swap on my rex it's worht it for the eaz of not have to deal with spring kits when doing drum brakes. i prefer rear disc they look cool even if they don't help you any with braking you can aggree they don't make it worse.
Old Feb 4, 2005 | 10:38 PM
1quickcrx's Avatar
Default Re: (88civichbz6)
once you swap to rear discs, you can use a big brake upgrade in the rear cant ya?
Old Feb 5, 2005 | 09:30 AM
Wes V's Avatar
Default Re: (1quickcrx)
I measured a 7 pound difference between the stock drums on my 89 SI hatchback and the DA disk brakes (per side).
Done on a cheap bathroom scale.
Wes
Old Feb 5, 2005 | 10:07 AM
B2FiNiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxb20ed &raquo;</TD></TR><TR><TD CLASS="quote">sounds good Ill be doing this this weekend,.. I got 00' gsr rears,, what ebrake cable can I use? and did you have a problem w/ you stock brake hoses? thanks!</TD></TR></TABLE>
Use 90-91 CRX Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOSS-REX &raquo;</TD></TR><TR><TD CLASS="quote">The weight differences is not enough to worry about.
I put disc brakes on the back of my 88 crx si and it stops better than before and my car didn't get slower from the extra weight, I used 90-93 teg disc, It also stops much better in the rain when the brakes get wet, looks more cool, they last longer than drum, easy er to change the pads, they don't fade down big hills, so put them on, and enjoy slamming on your brakes and stopping on a dime. </TD></TR></TABLE>
Brake shoes for drum brakes lasts MUCH longer than disc brakes but it is much easier as you stated to change pads vs shoes.
Old Feb 5, 2005 | 11:19 AM
rioninja's Avatar
I hate changing drum brakes. Its not really hard, but its just so damn easy to
change disk brakes instead.
Old Feb 5, 2005 | 11:22 AM
ElementMotor's Avatar
Yup. Did the same thing on my 88 HF and it stops better. I'm not concerned with the extra weight either (i love my car weighing in at 1900lbs even WITH the ls swap ), its not THAT much of a difference anyways. ****, u can offset the weight of the discs and get some lightweight rims.
Old Feb 5, 2005 | 08:26 PM
crxb20ed's Avatar
Default Re: weight diffrence of EF drums to Rear Discs?? (EF8 ownz U)
sounds good guys, did you guys also change you MC? I replaced mine a year ago, and I guess they accidently gave me a 15/16...weird but hopefully I wont have to replace it. and so the brake lines is a must then for the rear discs? my gsr's have the hoses still on them....I wonder how different they are, also I heard about all the bad things of swapping the 94 and up front integra spindles, I know I need to get DA's or 90-91 EX's, has any personally swaped these newer spindles on? even w/ the car lowered and w/ the ingles camber kit? let me know, thanks guys
Old Feb 6, 2005 | 06:50 AM
cursED's Avatar
I am running the EX knuckles with the 94+ calipers. You could do that.
Old Feb 6, 2005 | 07:47 AM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxb20ed &raquo;</TD></TR><TR><TD CLASS="quote">sounds good guys, did you guys also change you MC? </TD></TR></TABLE>
the mc isnt a big deal, the prop valve is however. doing a 40/40 prop valve swap is much better then stock and distributes the braking more evenly.
more info found here:
http://www.fourthgenhatch.com/reardiscswap.html
Old Feb 6, 2005 | 12:05 PM
crxb20ed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cursED &raquo;</TD></TR><TR><TD CLASS="quote">I am running the EX knuckles with the 94+ calipers. You could do that.</TD></TR></TABLE>
yeah but them things are about as hard to find as a pin in a hey stack
Old Feb 6, 2005 | 12:25 PM
R6Boy69's Avatar
cant be much if any... the disc might even be lighter, seems like there is alot less material
Old Feb 7, 2005 | 02:24 AM
crxb20ed's Avatar
Default Re: weight diffrence of EF drums to Rear Discs?? (crXBoy69)
havent got to do the swap yet, still waiting for my prop. valve and rear hoses, think my gsr hoses thats on right not will work??
kingcu90
May 30, 2010 07:56 AM
project midnight
Jan 12, 2007 12:39 PM
whole9
15
Apr 1, 2005 05:55 AM
H2nr
Dec 4, 2004 09:31 PM
uneekcrx
20
Apr 7, 2004 12:34 PM
