valvespring remover
Old Feb 1, 2005 | 02:53 PM
93b16's Avatar
Default valvespring remover
anyone know where i can get one? i have the little over head valve one from autozone but it doent work. for a b16 head
Old Feb 1, 2005 | 05:00 PM
PrettyLude's Avatar
snap-on
Old Feb 1, 2005 | 05:26 PM
T4eg's Avatar
Default Re: (PrettyLude)
i have a snap-on and matco, but craftsman makes one u can get it at sears if u dont wanna spend much $$.
Chris
Old Feb 1, 2005 | 07:02 PM
havok hybrid's Avatar
Default Re: (BlueHatch00)
to only take off the springs and retainers.. i use a socket and a hammer..
you take like a 19mm socket.. put it on the retainer.. and hit it it will compress the spring to fast.. .that the Keepers just fall out.. and then.. BINGO .. you got your spring and valve out and off...
but good look puting them back on.. WITHOUT the tool..
Old Feb 1, 2005 | 08:03 PM
whoa its len 2's Avatar
Anyone with a craftsman one from sears? Any reviews on it would be helpful.
Old Feb 1, 2005 | 08:52 PM
IN VTEC's Avatar
Default Re: (whoa its len 2)
You need an driver piece from goodson.com to use the C-clamp spring compressor from Sears. Without the driver, the compressor doesn't work on deep-skirted heads. It's much easier for one person to use with the head off the block than the overhead compressor.
Old Feb 1, 2005 | 08:57 PM
Redline130's Avatar
Default Re: (IN VTEC)
You need one of these: http://www.thetoolwarehouse.net/shop/SP-91400.html
Just like the Snap-On one, just cheaper.
Old Feb 1, 2005 | 09:28 PM
Lord Helmet's Avatar
Default Re: (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">You need one of these: http://www.thetoolwarehouse.net/shop/SP-91400.html
Just like the Snap-On one, just cheaper.</TD></TR></TABLE>
yeah that's what I've used to remove and install the valve springs on my ol' b18a engine. just use compress air to keep the valves up.
Old Feb 1, 2005 | 09:44 PM
PrettyLude's Avatar
Default Re: (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">yeah that's what I've used to remove and install the valve springs on my ol' b18a engine. just use compress air to keep the valves up.</TD></TR></TABLE>
that's alot cheaper than i paid for mines
Old Feb 2, 2005 | 04:47 AM
dnoredsi's Avatar
THAT ACTUALLY IS THE SAME ONE SNAPON CARRIES ON THERE TRUCK. THERE KNOWN FOR USING OTHER PEOPLES RELIABLE TOOLS AND BRANDING THEM SNAPON. I PAID 125.00 FOR MINE THEN I SAW THOSE ,DOH!!
gucci mane
Dec 12, 2013 07:48 PM
HumanResource
Jan 8, 2009 07:31 AM
boostd92
Sep 12, 2008 05:40 PM
street_ride14
Jun 30, 2007 11:54 AM
infinkc
Dec 24, 2001 12:46 AM
