My integra cranks but it wont turn on!!!!!!!
Old Feb 1, 2005 | 01:49 PM
sammysacura's Avatar
Default My integra cranks but it wont turn on!!!!!!!
Need help please!! I have a 2000 integra ls, I parked it in my garage. whent to turn it on,and now it cranks but does not turn on. Whats up?
I checked the sparks in each wire and i have spark, checked the fuel preasure and have preasure, checked the ing coil and its good, checked all the fuzes and all
are good. Please any one with an idea,, 'Call me collect or anything..
727-796-7873 or 216-702-7566 sam
Old Feb 2, 2005 | 05:29 AM
JimBlake's Avatar
Default Re: My integra cranks but it wont turn on!!!!!!! (sammysacura)
After cranking, pull the spark plugs & look for fuel. Just cause you have pressure in the rail, doesn't mean the injectors are firing.
Old Feb 2, 2005 | 10:59 AM
dick_213's Avatar
Default Re: My integra cranks but it wont turn on!!!!!!! (JimBlake)
doubtful its the injectors but you could run a volt ohm test on them.
Old Feb 2, 2005 | 11:18 AM
rgaray's Avatar
How many miles do you have on the Teg?
Old Feb 2, 2005 | 11:20 AM
shorto85's Avatar
When was the last time you replaced the cap and rotor?
Old Feb 2, 2005 | 01:41 PM
Kazz's Avatar
Default Re: (shorto85)
Bang ur Starter and try to start it again. .
Old Feb 2, 2005 | 01:55 PM
LSvtec03's Avatar
Default Re: (Kazz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kazz &raquo;</TD></TR><TR><TD CLASS="quote"> Bang ur Starter and try to start it again. .</TD></TR></TABLE>
if it's cranking, then the starter is not the problem. it's obviously doing its job.
Old Feb 2, 2005 | 02:35 PM
Irish Integra's Avatar
Maybe its the Crank Position Sensor (CKP) sensor? They die sometimes, won't let the car start if they do, sounds like something along those lines if you have spark and fuel...and presumably air?
Old Feb 2, 2005 | 02:39 PM
Mordeki's Avatar
Abusing my rights one day at a time.
Default Re: My integra cranks but it wont turn on!!!!!!! (Irish Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irish Integra &raquo;</TD></TR><TR><TD CLASS="quote">Maybe its the Crank Position Sensor (CKP) sensor? They die sometimes, won't let the car start if they do, sounds like something along those lines if you have spark and fuel...and presumably air?</TD></TR></TABLE>
damn, that's one n00b that knows his **** or maybe I'm just biased cause I'm Irish
Old Feb 3, 2005 | 04:03 AM
JimBlake's Avatar
Default Re: My integra cranks but it wont turn on!!!!!!! (Mordeki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irish Integra &raquo;</TD></TR><TR><TD CLASS="quote">Maybe its the Crank Position Sensor (CKP) sensor? They die sometimes, won't let the car start if they do, sounds like something along those lines if you have spark and fuel...and presumably air?</TD></TR></TABLE>Doesn't CKP sensor control spark timing? Without it, you don't get spark.
That also controls injector timing, but if the injectors aren't getting power thru their common leads, they don't fire.
sammysacura...
With all these ideas, which ones have you checked & ruled out?
Old Feb 3, 2005 | 08:17 AM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't CKP sensor control spark timing? Without it, you don't get spark.
sammysacura...
With all these ideas, which ones have you checked & ruled out?</TD></TR></TABLE>
JimBlake is my hero. seriously. to you man.
Old Feb 3, 2005 | 10:12 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: My integra cranks but it wont turn on!!!!!!! (95lstegman)
What about the battery?
Old Feb 4, 2005 | 03:47 AM
JimBlake's Avatar
Default Re: My integra cranks but it wont turn on!!!!!!! (You_Get_Vapors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">What about the battery? </TD></TR></TABLE>If it cranks strong, the battery's OK.
Old Feb 4, 2005 | 07:50 AM
TeaAddict's Avatar
don't post your phone #
maybe seomthing to do with fuel system
or your alternator.
Old Feb 4, 2005 | 12:16 PM
thanks for the info,, I finally turned the car on!!! You would nwver quess whats the problem,,,, I`ved made a new copy key for the car and it was the key, I never knew that i had a chip in the key
[/QUOTE]
Old Feb 4, 2005 | 12:19 PM
I was thinkin about the CKP sensor...there would be a CEL if it was dead anyway.
This may be obvious but did you check the spark plugs?
sammysacura...
I'd be curious to know what happens here, let us know...
Old Feb 4, 2005 | 12:43 PM
R4ND0M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sammysacura &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info,, I finally turned the car on!!! You would nwver quess whats the problem,,,, I`ved made a new copy key for the car and it was the key, I never knew that i had a chip in the key</TD></TR></TABLE>
redmon_e
Jan 5, 2015 11:47 AM
GTFODave
Mar 24, 2010 06:14 AM
szczerbanator
Jun 26, 2009 09:07 AM
TegProject
May 1, 2008 10:37 AM
AKprelude
Nov 12, 2004 02:24 PM
