any guys with a b18a swap in hf?
Old Feb 1, 2005 | 01:13 PM
crxhf19's Avatar
Default any guys with a b18a swap in hf?
what ecu are you running. does it ever throw codes? i have a pr4-a10 and it keeps on throwing code 13(barometric pressure) i just need a ecu that works in a hf that throws no codes so i can know which one to get. thanks so much
Old Feb 1, 2005 | 02:51 PM
crxhf19's Avatar
Default Re: any guys with a b18a swap in hf? (crxhf19)
bump
Old Feb 1, 2005 | 07:17 PM
RedSI93's Avatar
ive jsut got the stock ls integra computer in mine, i do not know the ecu number though.
Old Feb 2, 2005 | 04:31 AM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf19 &raquo;</TD></TR><TR><TD CLASS="quote">what ecu are you running. does it ever throw codes? i have a pr4-a10 and it keeps on throwing code 13(barometric pressure) i just need a ecu that works in a hf that throws no codes so i can know which one to get. thanks so much </TD></TR></TABLE>
Not sure whats throwing the code but the ecu you have sounds right if its obd-0 pr4
Old Feb 2, 2005 | 06:41 AM
stealth civic's Avatar
Default Re: any guys with a b18a swap in hf? (Magick211)
Your ecu is probably bad. I had the same motor in the same chassis and I got that code from a junkyard pr4 ecu. Got a chipped pr4 and hod no problems after that. Test another computer to see if yours is bad.
Old Feb 2, 2005 | 01:56 PM
NCchris's Avatar
https://honda-tech.com/zerothread?id=982646
HTH, worked for me.
chris
Old Feb 2, 2005 | 04:24 PM
rice a roni's Avatar
Default Re: (89LScrx)
dude you stole my picture in your avatar..
Old Feb 2, 2005 | 05:17 PM
crxhf19's Avatar
Default Re: any guys with a b18a swap in hf? (NCchris)
is this what i need to do to get rid of code 13?
Old Feb 2, 2005 | 05:18 PM
crxhf19's Avatar
i have tried 4 diff ecu's
Old Feb 2, 2005 | 07:39 PM
Reservation-Sensation's Avatar
i had the same problem in my 88 hatch the chip what u replace for like rev limit (don't know wat it is called) was all fukked up so i replaced it and now i have an pr4 L02 and now it runs hella good
89civichatchback
Feb 26, 2005 03:44 PM
crxhf19
Feb 2, 2005 10:48 PM
soquickls
11
May 25, 2004 01:25 PM
Prelude Vtec 23
Jul 20, 2003 06:05 AM
Type R
Dec 12, 2001 08:43 PM
