Fuel Filter Q's from EG DX & EX
Old Feb 1, 2005 | 01:08 PM
d15b7racer's Avatar
Default Fuel Filter Q's from EG DX & EX
I have a Civic DX and i cant seem to find a fuel filter for my car. My fuel filter has both inlet and return on the top where as the EX has inlet on the top and return on the bottom. are the two interchangeable without changing the fuel lines and fittings? what i wanted to do was buy a stainless fuel line from rail to filter but they only sell it for EX's. ALso when i go to a parts store they dont even have a part number or part for a DX fuel filter.
Old Feb 1, 2005 | 01:22 PM
JDMisGOOD's Avatar
Default Re: Fuel Filter Q's from EG DX & EX (d15b7racer)
go to you local honda dealership they will have what you need!
Old Feb 1, 2005 | 03:36 PM
speedfreek128's Avatar
92-93 has in and out on top.....94-95 has one on top other on bottom....unless it is Del Sol up to 94 has both on top.....that should be correct
Old Feb 2, 2005 | 10:54 AM
d15b7racer's Avatar
so what if i want to run a stainless line and aftermarket fuel filter? would i need to get a new return line from honda for a 94-95?
Old Feb 2, 2005 | 10:58 AM
d15b7racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfreek128 &raquo;</TD></TR><TR><TD CLASS="quote">92-93 has in and out on top.....94-95 has one on top other on bottom....unless it is Del Sol up to 94 has both on top.....that should be correct</TD></TR></TABLE>
Now that i think about...my car is a 94. so that cant be right.
Old Feb 2, 2005 | 11:06 AM
egsleepercivic's Avatar
I think in 92-94 had both on top, then in 95up the change to 1 on top and 1 on bottom
my 94 ex had both on top
Old Feb 2, 2005 | 11:53 AM
Street Ghost's Avatar
Default Re: (egsleepercivic)
i believe that's right.
my 93 ex has both on top, but my 95 vx has one on top and one on bottom.
Old Feb 3, 2005 | 06:46 PM
d15b7racer's Avatar
Default Re: (_Edge.ONE)
so in order to run an aftermarket fuel filter i'd need to change my return line to a 95 unit?
Old Feb 4, 2005 | 09:02 AM
little confused, the 2 lines on the filter are as follows 1 comes from the tank the other goes to the fuel rail..
the return line is at the other end of the fuel rail, and I do not believe it changed between the years 92-95 and possibly 96+
hope this helps
Old Feb 4, 2005 | 09:17 AM
EJ1 wilcox's Avatar
Default Re: (d15b7racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b7racer &raquo;</TD></TR><TR><TD CLASS="quote">so in order to run an aftermarket fuel filter i'd need to change my return line to a 95 unit?</TD></TR></TABLE>
No... any autoparts store should carry the correct filter for your car...
Just make sure you get the right one before you walk out the door.. .
Most of the time the guys working behind the counter don't know what they are talking about...
I just replaced the fuel filter in my daily driver and it was the same way... both inlet and outlet are on the top. What brand are you getting? I might have the part number handy...( I work for an autoparts distributor)
94DOHCDELSOL
Feb 4, 2005 11:00 AM
blkgsr03
Dec 9, 2003 12:04 AM
ATS*Mark
Nov 5, 2003 08:29 AM
decypha
Aug 20, 2002 03:55 PM
